Old 15-06-2010, 06:53 AM   #1 (permalink)
coolguy12374's Avatar
Default Motherboard Temperature warnings!!!!!
Friens, i ve recently assemble my pc wid an AMD Athlon II X245,ASUS M4A78-E Motherboard,Transcend 2GB DDR 2 800MHz,WD 320GB HDD,I-Ball cabinet with bundled 400w smps.The first time i start up my computer,i check the cpu n mb temperature through the bios but surprisingly found 37deg C for CPU and 80deg C for Motherboard which i think is very high.But my system runs smoothly,no hanging,tasks are handled well.So totally confused if da temp goes higher in load state it might blow up my cpu,mb or components.Please suggest.
coolguy12374 is offline   Reply With Quote
Old 15-06-2010, 08:27 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Motherboard Temperature warnings!!!!!
Do not look at the BIOS temperatures. Using the following in conjunction and correlate.
HW Monitor.
CoreTEMP.
Lavalys Everest
80C for motherboard is just not possible.
asingh is online now   Reply With Quote
Old 15-06-2010, 01:35 PM   #3 (permalink)
Cool Buddy's Avatar
yes, use some other softwares to check your system temperatures. Motherboard neve heats up that much.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 15-06-2010, 06:15 PM   #4 (permalink)
Thanx for the replies.Yeah i agree wid ur suggestions n vil ceck with core temp.But i too have check wid Asus bundled Probe II and Asus AI Suite, still shows 80 deg C wid a warning signal.So m totally confused.What sud i do now?
Old 15-06-2010, 08:35 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Which component is showing a warning...still..? Also update your signature, please, thanks.
Old 15-06-2010, 09:12 PM   #6 (permalink)
forget those Asus utilities. they are nothing but big jokes. download HW Monitor & check as the temperature as asigh told.
Motherboard essentials flamore_54 Hardware Q&A 10 27-04-2010 02:48 PM
How to get motherboard to power up flamore_54 Chit-Chat 0 25-04-2010 06:19 PM
Built ur own pc. rajas700 Tutorials 3 10-09-2005 09:33 AM
