Old 14-06-2010, 09:44 PM   #1 (permalink)
Talking Buying a AMD processor
Hello vrybody
i have a gigabyte G31M-ES2L motherboard. i planning a AMD processor. and suggestions. money is not much the matter but i need a powerful cpu and probably a full virtualization supported and overclocking.... any option without these are also welcome.
Raj kayshap
Raj_Kayshap is offline   Reply With Quote
Old 14-06-2010, 09:59 PM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: Buying a AMD processor
If u can spend around 13.5 k then core i7 930 has no match.
For around 10 k u can go for 1055t which is superb in multithreading. If gaming i5 750.
All these are oc friendly.
B/W please fill up a questionere u might find in some other posts so that we can suggest u a good config.
Old 14-06-2010, 10:01 PM   #3 (permalink)
Originally Posted by Raj_Kayshap View Post
Hello vrybody
Raj kayshap
you have a Intel G31 motherboard. to use AMD processor, you need a AMD motherboard. whats your budget? also whats your config?
Old 14-06-2010, 10:07 PM   #4 (permalink)
Oh and i forgot about mentioning that mobo
Old 14-06-2010, 10:46 PM   #5 (permalink)
budget is not a matter, i need a powerful processor and if i can i need options to have overclocking and virtualization
---------- Post added at 10:34 PM ---------- Previous post was at 10:18 PM ----------
---------- Post added at 10:46 PM ---------- Previous post was at 10:34 PM ----------
Old 15-06-2010, 12:09 AM   #6 (permalink)
look, if you going for virtualization & multitasking mainly, you can settle for AMD X6 1055T or X6 1090T BE. both are good processors & are OC friendly. & cost is moderate to tell the least.
on other hand you got Intel Core i7 930. another beast. settle for anyone.
amd troubles spm Hardware Q&A 15 27-05-2010 07:47 PM
AMD 12-core Opterons leaked ahead of launch? hot zubs Technology News 1 27-03-2010 03:58 PM
Please suggest cor2duo processor and motherboard & ram at 10k sanads Hardware Q&A 20 27-03-2010 11:19 AM
About AMD processor. parimal_xp2003 Hardware Q&A 5 16-02-2006 07:48 PM
