Old 14-06-2010, 01:54 PM   #1 (permalink)
Unhappy Dissorted or Scratchy sound.!
Hi.......these is my first post.......I love reading digit magazine.......And also the way they help there fans........:-P .
I have a strange problem......a scratchy sound comes out from my creative speakers whenever i do something like minimizing screen scrolling and also playing games these scratchy sound comes out.........also when i play HD 1070p movies and video the scratchy sound increases........I do lots of research but not found any result yet....... please help me out???I think maybe this problem is due to my graphic card.........
My PC Spec_________
Intel Celeron 1.6 GHz
1 GB ram
160 gb hdd
Nvidia Gforce 8400gs ddr2 512 mb
IDT high definition sound!
Ashutosh Rathore is offline   Reply With Quote
Old 14-06-2010, 03:33 PM   #2 (permalink)
Tron91's Avatar
Default Re: Dissorted or Scratchy sound.!
1. Try to fiddle in the Control Panel with the Sound Effect Manager. You could even try to re-install the audio drivers.
2. Do you keep ur mobile near the pc or ur woofer, it could also give out some irritating noises.
3. Might be even that ur woofer has got damaged.
4. If you think the Graphics driver is the culprit, remove it and just use the integrated graphics if present and check out the sound quality.
-- I am Old! I may be Primitive! But still I Rock! --
Intel C2D E7200 1.59 GHz, 2.53 GHz :: PIII Xeon :: 2 GB :: 250 GB + 320 GB HD
Tron91 is offline   Reply With Quote
Old 14-06-2010, 05:05 PM   #3 (permalink)
Super Moderator
asingh's Avatar
My PC Spec_________
1 GB ram
160 gb hdd
Which speakers you are using...? If they have an on/off switch, toggle that when the sound happens and it will disappear. This usually happens when components/and connectors get corroded inside. You can either get the changed, or buy a new one. Is it s average/cheap quality speaker. Mine is --- and it does that a lot. At times on channel totally fails, and I need to toggle on/off again.
asingh is online now   Reply With Quote
Old 14-06-2010, 05:52 PM   #4 (permalink)
Unhappy Re: Dissorted or Scratchy sound.!
First of all thnxx for reply.I had tried lots of time to reinstall the drivers but no befits from this.....
My speakers are new hardly 1 or 2 months later i had brought them for RS.2000 and yes there is a landline phone at the right side of the speaker i had tried to move it to somewhere else but the problem still persists.Also my woofers are ok.I will try to remove my graphic card and then check the sound!!!
Old 14-06-2010, 06:03 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Which brand..speakers.
Old 14-06-2010, 09:48 PM   #6 (permalink)
Cool Buddy's Avatar
mention the model of the speakers, we want to know. Rs. 2000 doesn't necessarily mean good speakers.
Check if the speaker is properly plugged into the socket, sometimes a loose plug may cause such sounds. Try plugging it into a surge protector.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 14-06-2010, 11:37 PM   #7 (permalink)
Super Moderator
asingh's Avatar
I got a set for 1800 (three nodes), and on the 2nd day the scratching noise started.
XP not starting sound card & onboard sound not working dipak15 Software Q&A 3 11-09-2009 06:10 PM
help.about blue screens.random messages.no hibernation hippi QnA (read only) 7 05-01-2006 07:52 PM
