Old 14-06-2010, 06:44 AM   #1 (permalink)
sidewinder's Avatar
Cool Minor mid life upgrade ~ Help Needed !
Guys ... I need your help !
My old PC needs some minor upgrades (Or should I say replacements )as some of the components are showing the signs reaching End of life. My PC usage has resorted to only using Internet and make power point presentations with occassional movie after getting my job so it should be as cheap as possible while maintaing the quality.
My current RIG is
1.AMD X2 7750
2.2 GB DDR 800 Transcennd
3.Asus M2N VM DVI
4.AOC VA 1917 LCD (19" wide)
5.Creative 4.1 Speakers ( 5years Old..taken from my previous rig )
6.HP DVD Writer 1035
and other usual stuffs...running Win 7 x64
Now the DVD writer has stopped working and the Creative speaker makes a lot of noise with frequent power fluctuations. So I've decided to replace it. Also need to buy some other component also...please suggest me the best options !
My requirements are
1. One good DVD writer (SATA )
2. 2.1 Speaker set (Budget ....but should be of brands like creative / altec lansing )
3. One Inkjet All in One with low running cost
4. One Internal TV tuner card which supports X64 Win 7 and Widescreen res
I will be buying from kolkata .. so please advise accordingly
Thnx and regards
Bombina rocks
sidewinder is offline   Reply With Quote
Old 14-06-2010, 12:28 PM   #2 (permalink)
Default Re: Minor mid life upgrade ~ Help Needed !
My current RIG is
1.AMD X2 7750
3.Asus M2N VM DVI
My requirements are
Thnx and regards
1. SAMSUNG SH-S223C (22X) ---> 1.1k
2. Creative SBS A300 ---> 1.3k
3. no idea sorry.
4. PixelView Play TV Pro 3 ---> 1.2k
Old 14-06-2010, 12:39 PM   #3 (permalink)
teh tech saviour!
saurabh_1e's Avatar
why samsung to have the tray problem after one year
better with lg or sony
altec lansing bxr1221
check out some officejet
like hp4355
or better go with cannon or samsung printers
AVER TV BOX GENIE 1 (M075) - 1450/
AMD Phenom x6 1055T @3.50ghz || MSI R6850 @925Mhz OC/PE || 2X2 GB RIPJAWS 1333CL8 || CM 460W REAL POWER ||Asus M5A97 EVO || Lancool PC-K62 || Sennheiser HD201+Fiio E5 || Logitech G400+Razer Golathius || Epson TX121 with CISS || Arch Linux ||
saurabh_1e is offline   Reply With Quote
Old 16-06-2010, 07:15 PM   #4 (permalink)
sidewinder's Avatar
Ok guys ...here's an update !
I've decided to beef up a bit for the speakers. I am going for Creative T6100 5.1 speaker system . Samsung SH 223 C seems to be the most widely suggested DVD writer so I am goting for it too !
__________________________
Now I am really confused about the All in One and TV tuner part.
HP cartridges are way too costly so no way I am gonna go for them ...so canon and epson seems to be the options ...any suggestion ?
And for the TV tuner ...should I go for external tv tuner or stick to internal one ? Which one would be better ?
Bombina rocks
Best Laptop with long battery life? KH_Global Laptops and Netbooks 5 30-07-2010 12:59 PM
Upgrade plans Buzz Hardware Q&A 15 17-06-2010 12:24 AM
Gamer for life! official Gamerz 6 02-05-2010 10:33 PM
Installing VLC in FC-6??? The Unknown Open Source 14 20-08-2007 06:39 PM
mobo upgrade..help needed neyo Hardware Q&A 1 06-09-2006 07:03 PM
