My friend had a similar experience.His PC wasnt starting immediately when he swtch it on.It was taking 5 min or so to start.It started after he put a 9400GT to the rig.His config was an old p4,asus mobo etc it was upgraded from an OEM PC.I told him that its SMPS problem and I went to check it.After opening the PC I was shocked; the rig was running in a 200W SMPS
What would be the actual out put ? 140-150W? He was playing games in that rig
Splinter Cell DA ran fine in that condition :-P.Then a Zebronics 450W Sata Plus was fitted and the prob solved.
