I have to upgrade my motherboard and processor within Rs. 10000.
I've shortlisted the following processors:
1) Core i3 530 Rs. 5850
2) Athlon II X3 425 Rs. 3700
3) Phenom II X2 555 Black edition Rs.5300
Which is better among 2) and 3) ? And is 1) better than both?
Will there be any problem with the Core i3 considering that it is relatively new? Can DDR2 be used with the Core i3 ? The processor needs to be reasonably future-proof.
Also, my current SMPS and UPS are 350W and 600VA(Numeric) respectively. Will they be enough for these processors?
Also, please suggest motherboards for the corresponding processor. My only constraints are that it should fit in my budget and I would prefer a DDR3 board. Features like solid state capacitors and E-SATA will of course be plus points but its not absolutely necessary.
I had once read in Digit about motherboards with onboard graphics which had its own discrete RAM but I can't remember which issue or the motherboard name.
I don't know what form factor my cabinet is so I'm posting its size.
l x b x h == 43 x 20 x 34 cm
