Old 12-06-2010, 06:33 PM   #1 (permalink)
Default Help required for RAM upgrade
Hello everyone,
I have two 1GB DDR2 RAM of Kingston running on 667 MHZ with timing 5 5 5 15. Can i install a new 2GB stick of Corsair DDR2 800 MHZ with 5 5 5 18 timing with the old Kingston RAM ?
Here is the screen short of Timings of my RAM.Please reply soon as i am upgrading my computer very soon.
dixit8611 is offline   Reply With Quote
Old 12-06-2010, 07:42 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Help required for RAM upgrade
You could. Just that all the sticks in conjunction will run at the lowest speed out of the two.
asingh is online now   Reply With Quote
Old 12-06-2010, 08:16 PM   #3 (permalink)
It means no blue screen, no system failure nothing ? Just i will get 4 GB DDR2 RAM running at 667 MHZ with 5 5 5 15 timing. IS it correct ?
Old 12-06-2010, 08:19 PM   #4 (permalink)
teh tech saviour!
saurabh_1e's Avatar
better get 2x2 corsair dual channel memory that will be much faster
or get another 1gb exactly same kingston ram to set up dual channel
AMD Phenom x6 1055T @3.50ghz || MSI R6850 @925Mhz OC/PE || 2X2 GB RIPJAWS 1333CL8 || CM 460W REAL POWER ||Asus M5A97 EVO || Lancool PC-K62 || Sennheiser HD201+Fiio E5 || Logitech G400+Razer Golathius || Epson TX121 with CISS || Arch Linux ||
saurabh_1e is offline   Reply With Quote
Old 12-06-2010, 08:38 PM   #5 (permalink)
---------- Post added at 08:38 PM ---------- Previous post was at 08:30 PM ----------
Will it perform in real world ? I mean most of the faster RAMs perform FASTER when tested by various benchmarking software, the performance difference is too low to be observable in real world ( I am not talking about softwares which really require big GB'S )
I want to use my computer entirely for gaming and other basic uses like browsing, music, watching movies. No video editing and no other heavy softwares.
Old 13-06-2010, 04:13 PM   #6 (permalink)
No replies .......????
Old 13-06-2010, 05:10 PM   #7 (permalink)
teh tech saviour!
saurabh_1e's Avatar
ya it will work but its better to have rams of same company and speed, frequency, timings etc.
Old 14-06-2010, 06:31 PM   #8 (permalink)
okkk thanks.
how to integrate .net framework required by a software application on to itself? chandra_S Software Q&A 10 27-05-2010 01:40 PM
Upgrade problem plz help. ajai5777 Hardware Q&A 56 14-05-2010 05:59 PM
PC upgrade [low budge] happy17292 Hardware Q&A 5 18-04-2010 09:48 PM
Free upgrade to 2 Mbps Airtel Broadband!! aashish.joshi Broadband and DTH 2 13-03-2010 10:40 PM
Windows 7 upgrade version: The dos and don'ts Gauravs90 Technology News 5 09-11-2009 11:02 PM
