I already had a Pro Tv 3 card.But as I shifted to Windows7,I wanted a Windows 7 Supported Tv Tunner, I bought Pixel View Pro Tv 4.
It is mentioned that it supports Windows 7.
But after I install the Software CD and the Drivers,It is not working.
When i was installing,
1.
Windows Security dialogue box showed :
Windows cant verify the publisher of this driver software.
Dont Install this Driver software...
Install this software anyway.
I gave Install this software anyway.
2.
Then,it showed
Windows encountered a problem installing the driver software for your device
Windows found driver software for your device but encountered an error while attempting to install it.
Windows cannot verify the digital signature for the drivers required for this device........
(Code 52)
I went to the pixel view website to check for their software updates,but i couldn't find any.
But The Tv Tunner Works fine on my XP.
Is there any way i can run my new Tv Tunner on my Windows 7.
Can anyone help me solving this problem ?I have attached some screen shots of the error messages.
