LinkBack (4) Thread Tools Display Modes
Old 10-06-2010, 03:21 PM   4 links from elsewhere to this Post. Click to view. #1 (permalink)
VIP
RazorbladeXtreme's Avatar
Default 1366x768 resolution not available
I recently purchased a LG Flatron W1943C and after installing the drivers from the disc provided I'm unable to get the option to set resolution to 1366x768. The resolution modes available are in 4:3 only - 800x600 and 1024x768.
I need to apply widesceen resolution, please help.
Twitter: twitter.com/SharmaTushar
Facebook: facebook.com/tushar.sharma
RazorbladeXtreme is offline   Reply With Quote
Old 10-06-2010, 04:23 PM   #2 (permalink)
pushkar's Avatar
Default Re: 1366x768 resolution not available
Does your graphics card support 1366x768 resolution? Which graphics solution do you have on your computer? Try installing (if you haven't) or updating the drivers for your graphics card.
pushkar is offline   Reply With Quote
Old 10-06-2010, 04:53 PM   #3 (permalink)
Super Moderator
asingh's Avatar
Are you using the IGP or a VGA to get the display output.
asingh is online now   Reply With Quote
Old 10-06-2010, 06:54 PM   #4 (permalink)
VIP
I don't know the difference, the port I'm using is same as the one I was using with my 4:3 CRT.
EDIT:
Sorry Pushkar, didn't see your post. I have onboard graphics and I use S3 Graphics ProSavageDDR driver version 6.14.10.12
Old 10-06-2010, 09:03 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Please give your full system configuration.
(I think I write "Please give your full system configuration." the most at TDF. Probably 1000/2335 post are "Please give your full system configuration.")
Old 10-06-2010, 09:42 PM   #6 (permalink)
Wise Old Ghoul
Piyush's Avatar
make that ur signature
will surely help
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 10-06-2010, 10:25 PM   #7 (permalink)
Cool Buddy's Avatar
How old is your motherboard? I don't think S3 will support wide screen resolutions. on top of it, you don't seem to know much. See if a BIOS update is available, that might help.
And in case you don't know your full system configuration, download speccy and see it there.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 26-12-2010, 12:19 PM   #8 (permalink)
So i was also not getting this resolution for my LG 1953T, i solved it by updating the Intel motherboard graphics driver.
Here is my thread
Monitor Resolution Keeps Changing
Demonic_Jack is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/128044-1366x768-resolution-not-available.html
Thread Why EA insist on not supporting 1366X768 resolution | EA Forums | BoardReader This thread Refback 26-11-2010 02:18 PM
1366x768 resolution not available - Digit Technology Discussion ... - ZapaFly This thread Refback 07-10-2010 08:19 AM
1366x768 resolution not available - Digit Technology Discussion ... - ZapaFly This thread Refback 05-10-2010 08:54 PM
1366x768 resolution not available - Digit Technology Discussion ... - ZapaFly This thread Refback 05-10-2010 08:53 PM
A Doubt in screen resolution....Pls help. giprabu Hardware Q&A 4 27-04-2010 10:04 PM
Screen resolution in UBUNTU pradeepcec Open Source 4 08-03-2010 12:29 PM
Need to change resolution in Linux Mint 8 (Provided By digit feb 10) thetechfreak Open Source 2 26-02-2010 06:42 PM
lost my screen resolution nims11 Software Q&A 2 18-01-2010 12:48 PM
Javascript:1024 X 768 Screen Resolution emailaatif786 QnA (read only) 5 15-03-2007 09:08 PM
