Old 09-06-2010, 11:45 AM   #1 (permalink)
Default Partial Upgrade for 15k required.
Hi,
My signature below mentions my current system. Now the mobo's BIOS is giving some trouble. Mobo is 5 years old and hence I am not interested in getting it repaired (servicing it through MSI will take atleast 10 days). Hence I want to replace old components with the following components:
CPU: AMD Athlon II X3 435
MoBo: MSI GF615M - P33
RAM: 4GB (Corsair)
HDD: Seagate 1TB
Cooler: CM Hyper 212 Plus
My requirement is some gaming (medium settings) and video editing (Nero and Ashampoo). My budget is around 15-16k. This system will be more of a fill-gap before I go for genuine power-rig (in 8-10 months).
Are the components shortlisted by me good enough? Also, how much (money) can I expect from the components which I will discard. Apart from the mobo all other components are working flawlessly and have no trouble.
Thanx.
AMD Phenom II X4 955 BE, Asus M4N98TD EVO, 2x2 GB G.Skill @ 1600MHz, MSI GTX 560Ti Hawk, 500GB Western Digital Black SATA-II, Dell Ultrasharp U2311H, CM 690, Corsair VX550
monkey is offline   Reply With Quote
Old 09-06-2010, 11:58 AM   #2 (permalink)
Default Re: Partial Upgrade for 15k required.
any X3. preferably X3 440.
Biostar TA785G3+
RAM: 4GB (Corsair)
check price difference between Kingston & Corsair before simply opting for corsair.
HDD: Seagate 1TB
check Samsung F3 Eco. its a bargain at that price.
Total: ~17k (if you consider my options)
expect around 4k (2k for ram).
Old 09-06-2010, 02:01 PM   #3 (permalink)
bORn To RIse....
rahul.007's Avatar
get kingston 2*2gb 1333mhz ddr3 for 5.6k... price diff. b\w it and corsair is of about 0.8k-1k....
no need to get cm hyper 212 plus.... get it when you get your new system....
and go with bio* mobo suggested by sam.... d0nt go with nvidia.... bio* mobo is pure vfm get can beat the hell out of MSI GF615M - P33....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline   Reply With Quote
Old 09-06-2010, 02:50 PM   #4 (permalink)
in features mainly. as OP already have a 9800GTX+
Old 09-06-2010, 04:03 PM   #5 (permalink)
That is the reason I opted for nvidia chipset based MoBo. I am comfortable with nvidia drivers especially while using linux.
BTW how is the OC potential of the nvidia-chipset based mobos?
Old 09-06-2010, 04:04 PM   #6 (permalink)
Techie By Heart
mavihs's Avatar
Can you fill the below questionnaire so i can suggest you a good config!
1. What is your MAX budget?
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
3. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
4. Planning to overclock?
7. What resolution will the screen run at?
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 09-06-2010, 05:02 PM   #7 (permalink)
1. What is your MAX budget? 16k
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why? yes
3. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that) games (medium settings - typically@ 1280x1024 resolution), video editing (use Nero/Ashampoo/DivX converter)
4. Planning to overclock? yes (but only sometimes)
5. Which OS are you planning to use? Win7 / Linux
6. How much hard drive space is needed? 500GB or above
7. What resolution will the screen run at? 1280x1024
8. How would you rate your hardware knowledge from the count of 1-10? (1 being the lowest, 5 being you are somewhat in sync with the current performers and 10 being the highest) 8
9. Have you ever built a desktop before or will this be done by an assembler? Will be self assembled
10. When are you planning to buy the system? 3-4 days
11. Are you one of the types looking out for "future proof" configurations? no
12. Are there going to be any components that you don't want to include in this new rig? If yes, do mention. Exclude cabinet/PSU/monitor/GFX card/keyboard/mouse/ODD/Speakers
13. Which city do you live in and are you open to buying from shops from other city/states? Delhi
14. Mention any other points if deemed necessary No
Old 09-06-2010, 05:46 PM   #8 (permalink)
Biostar motherboard OC potential is always counted among the best. if you can get the Biostar TA785G3 HD.
about driver problem, i not sure though.
Old 09-06-2010, 06:00 PM   #9 (permalink)
Biostar TA785G3 HD will force me to overshoot my budget.
Old 09-06-2010, 06:20 PM   #10 (permalink)
it'll cost you 1.5k more (total 17.5k)
Old 09-06-2010, 07:09 PM   #11 (permalink)
pulsar_swift's Avatar
when buying a pc, always keep in mind "a pc is not a tv or car".
what are the major differences ?
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline   Reply With Quote
Old 09-06-2010, 07:28 PM   #12 (permalink)
have you ever heard someone getting an assembled car? engine from GM, frame from Audi? exhaust system from Lamborghini & suspension from Mercedes?
also about TV, can you run a TV 24X7? and TV won't go bad? also can the same above idea b applied to TV? assemble a TV? i think you got the idea of what msg i want pass bro.
Old 09-06-2010, 09:22 PM   #13 (permalink)
ok. got it now.
Old 09-06-2010, 10:22 PM   #14 (permalink)
Cool Buddy's Avatar
one has to be much more careful while buying a PC as compared to a TV, but car??? One has to choose a car very carefully too, although, it cannot be assembled.
Old 09-06-2010, 11:35 PM   #15 (permalink)
car will vary vary by efficiency (mileage), looks, service provided by the center, etc. a pc: get a BAD psu & you compromising the PC's safe & in a more brief term, its existence. get a out of balanced PC (visit Dell to know what is an OUT OF BALANCED PC), even after paying 65k, you'll be unsatisfied by end the result (games not run well). its like that.
how to integrate .net framework required by a software application on to itself? chandra_S Software Q&A 10 27-05-2010 01:40 PM
Upgrade problem plz help. ajai5777 Hardware Q&A 56 14-05-2010 05:59 PM
PC upgrade [low budge] happy17292 Hardware Q&A 5 18-04-2010 09:48 PM
Free upgrade to 2 Mbps Airtel Broadband!! aashish.joshi Broadband and DTH 2 13-03-2010 10:40 PM
Looking to buy a Mobile, your help is required friends! Thor Hardware Q&A 3 22-01-2010 01:51 AM
