Old 09-06-2010, 01:27 AM   #1 (permalink)
Default Is this A hardware problem?
The problem started a few days back. i started getting BSOD randomly on my Windows Vista Home Basic after a fresh a instal and a day of updating from the windows update. The updates failed to install most of the times, but eventually after a few tries it worked. Except for the SP2. i tried installing it once , but failed. and the BSODs started. Even after a system restore,it didnt work. So i tried installing it again, and the OS got stuck in an infinite loop of restart-> reverting update changes -> restart -> and so on.
so i tried to startup repair and the safe mode, both failed.
After hrs of try, i did a clean format, and tried installing Windows 7 Enterprise edition trial from the digit DVD.
But in every install i am facing a BSOD, each with different error.
sometimes MEMORY_MANAGEMENT, some times PAGE_FAULT_IN_NONPAGED_AREA , and odr times just a BSOD.
Even after smhow once it would install, wen the OS boots for the first time , i have a BSOD just before the welcome screen.
I tried My friends Windows 7 disc (Ultimate), and the same problem.
At times the DVD wouldnt boot saying "NDIS.sys" not found.
I thought the problem might have been the RAM or my graphics card so i removed them both, and replaced my ram sticks with my older ones. Still the problem continues. (Exccept its a lot slower thanks to less ram and no GFX card D: )
Is all hope really lost ? :S
PLZ HELP
---------- Post added at 01:27 AM ---------- Previous post was at 01:26 AM ----------
This time i got CHACHE_MANAGER bsod.
malay.keshav is offline   Reply With Quote
Old 09-06-2010, 05:12 AM   #2 (permalink)
Cool Buddy's Avatar
Default Re: Is this A hardware problem?
is it possible for you to try to install it from a different DVD writer or a pen drive? Doesn't seem to be a hard disk problem. Try using a live CD (Like linux or Hiren boot CD) and see what happens.
Old 09-06-2010, 08:09 AM   #3 (permalink)
Super Moderator
asingh's Avatar
Zip the last 5 memory dumps, and upload them here. They should be at:C:\Windows\Minidump.
Sort them by date modified, and pick 5 most new. Also, please tell us your complete system configuration.
asingh is online now   Reply With Quote
Old 09-06-2010, 11:43 AM   #4 (permalink)
@Cool Buddy
I tried Using Hiren Boot CD.
Everything looked normal there.I tried repartitioning, Full Format . But nothing. Still Getting The same errors.
@Asigh
I formatted the Hard Disk during the Windows Installation. So the Dump files are lost.
Now i have also run Windows Memory Diagnostic Test and received 30,000 LRAND errors.(WMD From the Hiren Boot CD).
Also Now, None of the Boot CDs r working. Not Windows, Linux or anything :S
---------- Post added at 11:26 AM ---------- Previous post was at 11:18 AM ----------
My System Config is As follows ::
Intel Core 2 Duo 2.13 GHZ (4 MB L2 Cache)
(512 x 2 + 2048 x 1) MB DDRII Ram
Geforce 8800 GT 512 Mb
160 GB Samsung HDD
Targan 500W PSU
Its a Dell Dimension E050, but sadly way past its warranty period.
Also in the Memory Diagnostic Test, All the tests are passed except for the LRAND.
---------- Post added at 11:43 AM ---------- Previous post was at 11:26 AM ----------
And Yes. i did try installing using a USB.
But now even the Boot is failing. 3 out of 5 times, Hiren or Windows Boot Fails.
And even if it does, Most of the tools dont work. :\
Is it really the RAM? Or my motherboard? or the PSU ?
The PSU is the newest hardware to be installed about 6 months ago.
Old 09-06-2010, 11:48 AM   #5 (permalink)
pulsar_swift's Avatar
Try replacing your DVD ROM. If it doesn't work, your HDD has gone KAPUT.As you said you replaced the RAM and it still dint work.
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline   Reply With Quote
Old 09-06-2010, 11:53 AM   #6 (permalink)
I tried the USB . but still the same problem.
The problem is only getting worse, everytime i boot :S
More BSODs and File Not Found errors, less Boots.
Old 09-06-2010, 11:54 AM   #7 (permalink)
hhm, May be setup is unable to write files to your HDD ?
Old 09-06-2010, 12:05 PM   #8 (permalink)
I thought the same, but the HDD diagnostics show no problem in the Harddisk. But around 30,000 LRAND errors in the RAM :S
I will check the 3 RAM sticks one by one and then post again soon.
---------- Post added at 12:05 PM ---------- Previous post was at 11:56 AM ----------
So i ran the tests one by one on each RAM stick. And each of them has a problem.
But how can all 3 RAM have a LRAND problem all at once? 2 of them are factory default and the third one is new(8 months old).
Old 09-06-2010, 12:18 PM   #9 (permalink)
Check this URL.
http://www.techspot.com/vb/topic76246.html
http://www.ocztechnologyforum.com/fo...-Help-Me/page2
Old 09-06-2010, 12:24 PM   #10 (permalink)
Thanks. But i have no new hardware changes. The Problem started after a fresh Vista Install.(Followed by hrs of Update)
My hardwares were working fine for almost past one year.
Old 09-06-2010, 12:27 PM   #11 (permalink)
check the second URL.
Old 09-06-2010, 02:00 PM   #12 (permalink)
Post Re: Is this A hardware problem?
I checked all my RAM sticks one by one. All of them have LRAND error.
But since the error is on all of them , i am thinking that maybe the Motherboard is Frying my RAM sticks or is it just 3 new RAM sticks for me? :S
---------- Post added at 02:00 PM ---------- Previous post was at 01:25 PM ----------
So i have Run All the Diagnostics there is to run.
Everthing is PASSED except for the RAM (specifically the LRAND, in Windows Memory Diagnostic Tests and Memtest86 http://img3.imageshack.us/img3/3184/10062010008.jpg )
I guess that explains everything.
The BSODs in the Games durning the past 2 weeks, the BSOD during the Windows Install (as it makes a RAM Drive to install) and the Problems in the boot of Hiren's Boot CD which again makes a RAM Drive.
The most surprising thing is that all 3 of my RAM sticks are gone at once.
Most prolly due to the over heating Issues or keeping my computer ON for 4-5 Days non stop. Or maybe running Graphic and memory Intensive Games and programmes.
Will Post a reply when i get a new set of RAM sticks, which might take time as i am really short of money thanks to my new Digi Cam and Desktop Speakers(Which i cant use at the moment).
Hopefully the New RAM works.
Cheers on my First Hardware Failure.
Old 09-06-2010, 02:54 PM   #13 (permalink)
what is that 2361Mb/s in the screenshot ?
Old 09-06-2010, 02:57 PM   #14 (permalink)
I think its the transfer Rate.
Old 09-06-2010, 02:58 PM   #15 (permalink)
i know man, transfer rate of what and between what ?
Old 09-06-2010, 03:03 PM   #16 (permalink)
to test the RAM, memtest writes data onto RAM and den reads it, i suppose , dat transfer rate maybe.
Old 09-06-2010, 03:11 PM   #17 (permalink)
Ok, man your chipset FSB and memory speed are matching. So no problem on that front.
Old 09-06-2010, 03:59 PM   #18 (permalink)
Techie By Heart
mavihs's Avatar
most prob a Mobo problem!
try the RAM in your friends PC!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 09-06-2010, 07:52 PM   #19 (permalink)
Exclamation Re: Is this A hardware problem?
:C_tired:
So i replaced my RAM,Hard Disk And even the PSU with brand new ones and removed my graphics card. And guess wat ? It still didnt work
So in the End either the NEW RAM got fried as well, meaning a problem with the motherboard or the RAM is fine and my motherboard is Fried.
Either way, i need a new Motherboard.
Any other ideas? I dont want to waste my money on a new Motherboard to find it doesnt work as well.
Old 09-06-2010, 08:03 PM   #20 (permalink)
Super Moderator
asingh's Avatar
How you so sure, the new ram is also damaged..? Did you try it on another system..?
Old 09-06-2010, 08:08 PM   #21 (permalink)
no i havnt :S
Even in the new RAM it showed the same errors.
But 4 RAM sticks, all fried, must be the motherboard , no?
Old 09-06-2010, 08:19 PM   #22 (permalink)
why not u brought your friends mobo and check it. if everything goes fine then its mobo prob.!! also have u checked your processor
abhijangda is offline   Reply With Quote
Old 09-06-2010, 08:33 PM   #23 (permalink)
The Brand New packed RAM , Hard Disk And PSU were brought by a guy from a local service center nearby.So i doubt they were faulty.
My friends here dont have this kind of Config. All of them DDR I or using a laptop.
What and how do i test in a processor?
Old 09-06-2010, 09:49 PM   #24 (permalink)
Cool Buddy's Avatar
You should not have plugged in the new RAM without checking your mobo. You might have damaged a perfectly new piece of hardware. It would be better to get your PC checked at some computer repair shop, if there are any nearby. They can check voltages etc. with specialised tools, they'd be able to advise you better.
Old 09-06-2010, 10:09 PM   #25 (permalink)
this is getting interesting. I will watch this thread
Old 09-06-2010, 10:58 PM   #26 (permalink)
I did call a guy from the local repair shop.
The Good ones are in Nehru Place(Quite Far for me), n i dont trust them much.
The New Hardwares were all his. No loss on my side.
And he didnt check nething like the voltage though :S
Only way out now is Buying a new Motherboard and processor (since the problem is in one of dose two. Most prolly the Mobo)
Ne Suggestions of a good Motherboard and Processor Combo under 10k ?
And Since i have a Dell system,i would have to buy a new case as well :\
---------- Post added at 10:58 PM ---------- Previous post was at 10:57 PM ----------
I was surprised myself , wen all those New Hardware didnt solve the problem.
Hope the Thread ends with "Problem Solved"
Old 10-06-2010, 12:32 AM   #27 (permalink)
Super Moderator
asingh's Avatar
no i havnt :S
I doubt even one is fried. You are just jumping to conclusions. You will need another test bed. Else you can keep spending money and accumulating more parts, on the assumption they have gone defunct.
Old 10-06-2010, 12:36 AM   #28 (permalink)
I think so too, that the RAM sticks are ok.
But there is a hardware thats faulty. and its most probably the motherboard. Or the RAM, considering i am really unlucky with RAMs.
Old 10-06-2010, 05:24 AM   #29 (permalink)
Cool Buddy's Avatar
the repair shop guy couldn't even locate where the problem was? why doesn't he close down his shop? I too think that the RAM sticks are OK, but there's no way to check. couldn't you call a person from Dell?
Old 10-06-2010, 10:44 AM   #30 (permalink)
That guy had nvr worked with Vista.And he called my BIOS as vista startup
I told him to change the Hard Disk , RAM and PSU and check. which he did, and the problem was still dere.
All the local repair shops are like this here :\
I will have to take it to nehru place...and dats far far away.
Drivers musiclover5566 Software Q&A 5 23-05-2010 11:55 AM
New asus P5QPL-AM MOTHERBOARD PROBLEM sanads Hardware Q&A 4 15-05-2010 04:45 PM
Problem with Soundmax Audio Driver Amitava83 Software Q&A 0 14-04-2010 10:41 AM
Screeching problem raviramgopal Hardware Q&A 0 07-04-2010 12:06 PM
Wierd LCD problem Psychosocial Hardware Q&A 2 10-03-2010 02:20 AM
