Is there any possibility of getting Liqiud Cooling Parts in Delhi
for i7 920
Plz Inform where can i get them?
If NOT then Suggest a good air cooler for the same for around 3K!!
Thanks !!
3k is only for air cooling!!
For the Liquid One i Can spare 12K-14K
I can't order them Online so wanna know IF any shop in delhi retail CPU block, radiator n stuff.
BTW h50 sucks no room for enhancement!!
increase your budget a bit & get Thermalright Venomous X for Air Cooling!
for liquid cooling you'll have to import most of the stuff!
whats your location? a friend of mine recently got a LC setup for 15K around, if you want i can get you in touch with him.
Liquid Coolers available in India -> Corsair H50 --- INR 4.5k
CoolerMaster AquaGate Max ---- INR 14k
Otherwise direct import is the only other solution.
AMD Phenom II X4 955 BE, Asus M4N98TD EVO, 2x2 GB G.Skill @ 1600MHz, MSI GTX 560Ti Hawk, 500GB Western Digital Black SATA-II, Dell Ultrasharp U2311H, CM 690, Corsair VX550
How much will the VenomOUS X cost? & where Can i Get it In delhi..
I m in delhi !!
