Old 07-06-2010, 10:14 AM   #1 (permalink)
Default Where should i connect my mic?
i have a Creative Inspire M5300 5.1 channel system. the problem is, the subwoofer has
got a 3 pin connection which is connected to the on-board sound card of my computer. now there is no place left for connecting a mic. how can i solve the problem?
murphyker is offline   Reply With Quote
Old 09-06-2010, 07:49 PM   #2 (permalink)
Default Re: Where should i connect my mic?
first tell me whether your all speakers are working fine..
(they shouldn't be...)
if your mobo has 6 ports, 4 of them can be used for connecting speakers as centre, rear, side and woofer... the remaining are line line out and mic..
Phenom II X6 1055T|Gigabyte 880GM-USB3|Transcend 4GB DDR3 1333MHz| Benq G2220HD|PowerColor Radeon HD5770|Seagate 500GB|Logitech MK250|CM Elite 310|Zebronics Pro 600w|Creative A100 2.1 speakers|LG DVD|
giprabu is offline   Reply With Quote
Old 09-06-2010, 10:25 PM   #3 (permalink)
Cool Buddy's Avatar
Connect the mic to the front conenctors.
Tell us which motherboard you have, how can we answer like that?
Old 11-06-2010, 11:37 AM   #4 (permalink)
My motherboard is asus m2n-mx-se plus
Old 11-06-2010, 11:45 AM   #5 (permalink)
Cool Buddy's Avatar
So your front panel audio ports are not working. do the following
during boot press delete key to enter BIOS
Goto advanced>southbridge chipset configuration
Goto front panel select
If it is set to HD Audio, change it to AC97. Now your front panel should work & you can plug your mic there. This instruction is available in the blue user manual of your motherboard (Page 2-24 if you have the same book as me)
---------- Post added at 11:45 AM ---------- Previous post was at 11:44 AM ----------
tell me if it worked or not. And in case it is set to AC97 by default & it isn't working, try changing it to HD Audio
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 19-06-2010, 09:35 PM   #6 (permalink)
thanks cool buddy, thanks a lot, let me see if it works with my mb!
Safe to connect UPS with Inverter ?? bajaj151 Hardware Q&A 8 04-08-2010 11:41 PM
How To Connect Pc And Laptop With Router ?Plzzz Help sumitkala Hardware Q&A 9 12-04-2010 12:04 PM
need bluetooth head phone with mic for voice chat ashishstillthere Hardware Q&A 7 15-03-2010 08:49 PM
Windows 7 MIC not working with HD audio happy20b Software Q&A 0 11-03-2010 12:41 PM
having, Lappy,FM Mic, a Deck and Karoake musics-how to connect all together and ,,?? mobileman Tutorials 1 26-03-2008 09:07 AM
