Old 06-06-2010, 07:49 PM   #1 (permalink)
Exclamation DVD Writer not detecting CDs
Hi guys.
I have a Dell XPS M1530 which has a slot load drive....
Just recently I realized that it is not detecting CDs.
I am able to write DVDs, read DVDs and even write CDs but the CDs can't be read! The written CDs are detected on other comps but not mine
I have updated the BIOS to the latest version but that didn't help.
Config:
Windows 7 Ultimate, 3GB RAM, Intel Core2 Duo T8100 2.1 GHz
garfield87 is offline   Reply With Quote
Old 06-06-2010, 07:53 PM   #2 (permalink)
teh tech saviour!
saurabh_1e's Avatar
Default Re: DVD Writer not detecting CDs
time to get new dvd writer
AMD Phenom x6 1055T @3.50ghz || MSI R6850 @925Mhz OC/PE || 2X2 GB RIPJAWS 1333CL8 || CM 460W REAL POWER ||Asus M5A97 EVO || Lancool PC-K62 || Sennheiser HD201+Fiio E5 || Logitech G400+Razer Golathius || Epson TX121 with CISS || Arch Linux ||
saurabh_1e is offline   Reply With Quote
Old 06-06-2010, 09:11 PM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
^try updating the firmware!
VarDOS is offline   Reply With Quote
Old 06-06-2010, 11:36 PM   #4 (permalink)
Hi Varad
I cannot find the firmware for the drive
TEAC DVD+-RW DVW28SLC
I have googled for quite sometime but to no avail.....
Old 07-06-2010, 10:33 AM   #5 (permalink)
Section Moderator
gopi_vbboy's Avatar
did u keep CD reverse or wat?
try cleaning the CD'S radially out ward direction with cloth n put in drive
not working then go for service
gopi_vbboy is online now   Reply With Quote
Old 07-06-2010, 04:03 PM   #6 (permalink)
I'm amazed how you could even type that, given your experience on the forums....
Old 07-06-2010, 09:57 PM   #7 (permalink)
Section Moderator
gopi_vbboy's Avatar
^^sry was kidiing...i understand ur frustration...why dont u get it repaired...thers no point in posting such hardware problem in forums
Old 07-06-2010, 11:29 PM   #8 (permalink)
Appreciate that gopi_vbboy... Apparently it is a known issue in this model.... I've found some threads over Google... But then can't even find the driver anywhere.... Something to do with non finalized disks not being able to be read by the drive. But am not able to solve that...
LG DVD Writer Cant read Cds but Reads All DVDS... hmmmmmmmmmmmmm QnA (read only) 4 07-10-2007 08:12 AM
WinX DVD Author the best tool to Personalized DVD from Your Own Video in Clicks bigit Random News 2 21-06-2007 01:15 PM
