Old 06-06-2010, 07:45 AM   #1 (permalink)
Cool Buddy's Avatar
Default My home made water cooling
I recently bought a new HDD and I am using it with a tech com case. I wanted to use the HDD continuosly, so was looking for a case with a fan, but I couldn't find it. Now when I was using the HDD for over 2 hours, the temperature went to 47 degrees. Although not too high in summer, something struck my mind
The case is made of metal, so it absorbs heat from the HDD. I took a piece of cloth, soaked it in ice-cold water, drained all the extra water so that it doesn't drip from the cloth and wrapped the cloth around the case. In 10 minutes time the temperature came down from 47 degrees to 44 degrees. The water cooling worked!
Old 06-06-2010, 09:03 AM   #2 (permalink)
6x6
half way there
6x6's Avatar
Default Re: My home made water cooling
keep track of moisture...
Intel C2D | G31 | 2GB | 320GB
6x6 is offline   Reply With Quote
Old 06-06-2010, 10:49 AM   #3 (permalink)
Cool Buddy's Avatar
I'm not gonna use this regularly, I was just trying if it works and wanted to the share the experience. And also, since th case is completely closed, no moisture should get inside (I hope).
Old 06-06-2010, 11:13 AM   #4 (permalink)
nice work. water cooling HDD by 3degree !!! first time seen such an idea
Old 06-06-2010, 11:31 AM   #5 (permalink)
BE FREE
absolutely no no, not a good practice , as sudden cooling would result in moisture to condense in the case, which could harm the hdd.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline   Reply With Quote
Home Theater Installation commflat Technology News 0 05-06-2010 03:14 PM
water cooling arshadmajeed Hardware Q&A 1 16-05-2010 11:02 PM
Upgrading Windows 7 home premium 32 bit versions to Windows 7 home premium 64 bit ver dare_devil Software Q&A 1 07-02-2010 09:34 PM
NVIDIA overclocking,tweaking and cooling....All info you nee funkymonkey Tutorials 6 01-09-2005 08:46 PM
help me wid win xp services... mohit Software Q&A 2 12-03-2005 09:53 PM
