Hi all and thanks for all the support you have given me in the past. This time I am building an HTPC. I will also need it for some casual gaming, Age Of Empires III must run fine on it.
I already have a 500GB HDD and a UPS.
Here are all the components that I need:
Monitor: I would go for some 24" lcd if it fits my budget.
But please recommend an lcd which does not have any problem such as pixel dying.
CPU, Motherboard and RAM: I will use this system for some programming and browsing at most. So I guess I don't need very powerful CPU. And I don't care if its an AMD or Intel as long as its the best bang for bucks.
Graphics Card: Well as I said I need if to be good enough for some casual gaming. AoE 3 must run well on it.
Internal TV tuner card: Suggest me something which is good enough for my screen size and nothing more.
Speakers: I have decided on Altec Lensing vs2421 @2.2k. Please see if it is a good choice.
cabinet and SMPS : A normal full size cabinet is ok.
All sort of suggestions are welcome. And thanks in advance.
---------- Post added at 04:40 AM ---------- Previous post was at 03:37 AM ----------
Well I am a bit confused whether I should go for an HTPC or an Xbox 360 or PS3. With a gaming console I will have to buy a monitor too. So PS3 is clearly out of my reach for now at 26k. Xbox 360 Arcade does not have any hard disk so I wont go for it either. Xbox 360 Elite seems to be the only option other than the HTPC.
And will I be able to browse the web on Xbox?[COLOR="Silver"]
