Old 05-06-2010, 03:13 PM   #1 (permalink)
Default Temperature is shooting up.... Help me guyz...
look at this ..
are those temp. in yellow color indicate "danger" ..?
what the cpu0, cpu1 and cpu2 denote..?
the above situation occurs when playing any games..
and also the chassis speed of 6550 rpm is a bit noisy..
but when the a/c is turned on, the hdd temp goes down below 38 degrees and the remaining temperatures drop below 45.. and also the chassis fan speed also drops to 3700 rpm and runs quiet..
is this normal or should i add an extra fan to my cabby ?
Phenom II X6 1055T|Gigabyte 880GM-USB3|Transcend 4GB DDR3 1333MHz| Benq G2220HD|PowerColor Radeon HD5770|Seagate 500GB|Logitech MK250|CM Elite 310|Zebronics Pro 600w|Creative A100 2.1 speakers|LG DVD|
giprabu is offline   Reply With Quote
Old 05-06-2010, 05:33 PM   #2 (permalink)
Cool Buddy's Avatar
Default Re: Temperature is shooting up.... Help me guyz...
Temperatures of 50 degrees while playing games is normal, nothing to worry about. HDD temperature os around 42-43 degrees is also OK. it is yellow because softwares consider 50 as warning temperature. CPU1 & CPU2 denote the 2 cores of the processor, don't know what CPU0 denotes. It seems in your case fan RPM increases according to the temperatures, that's why it falls when AC is turned on and temperature comes down
(a/c is used to denote account as in bank account. Air conditioner is AC)
Old 05-06-2010, 05:54 PM   #3 (permalink)
oh thanks..
and my gfx card is also not detected by that software..
if cpu1 and cpu2 denote the processor cores, then wat about the remaining 4 cores ??
Old 05-06-2010, 06:07 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Try it with HW Monitor. Those temperatures are fine. Or try Everest Lavalys.
asingh is online now   Reply With Quote
Old 05-06-2010, 09:24 PM   #5 (permalink)
Cool Buddy's Avatar
You can also use Speccy to see the temperature of your gfx card
Old 06-06-2010, 10:21 AM   #6 (permalink)
yup..!!
speccy is pretty good and is free too..
thanks dude..
Old 06-06-2010, 10:53 AM   #7 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Best is CPUID's HWmonitor
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 06-06-2010, 11:26 AM   #8 (permalink)
BE FREE
Originally Posted by giprabu View Post
oh thanks..
count starts from 0, so cpu0 is your first core and cpu1 is second and so on, better check with HW monitor ........
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline   Reply With Quote
Old 10-06-2010, 06:58 AM   #9 (permalink)
pulsar_swift's Avatar
Check with CPU ID Hardware Monior. How many fans do you have on the case ? Do you have a 120mm fan near the PCI-E slot ? At what speed is ur CPU fan running ?
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline   Reply With Quote
Overclocking Athlon II X4 630. ajai5777 Overclocking 67 02-03-2011 06:58 PM
fan control and temperature display arshadmajeed Hardware Q&A 1 14-05-2010 08:56 PM
guyz heard about lockerz.com ?? NoasArcAngel Internet & WWW 25 13-04-2010 11:07 AM
Hey guyz...........is Nokia N900 worth waiting ?? paper_heart_21 Mobiles and Tablets 15 19-03-2010 11:06 PM
Safe working temperature of CPU and GPU abhijit_reddevil Graphic cards 9 09-05-2006 02:32 AM
