Old 04-06-2010, 10:15 PM   #1 (permalink)
Cool Buddy's Avatar
Default Buying a system for round the clock operation
I need to buy a system for my dad's office which will remain on all the time (connected with security cameras). Performance is not much consideration, budget is around 22-25k without monitor. I need only the basic components i.e. processor, motherboard, RAM, HDD, PSU & cabinet. any other component will be installed by the people installing the cameras. I've thought of the following:
Phenom II X2 550 Black Edition - 4.5k (since it runs cool)
Motherboard - Gigabyte GA-MA785GM-US2H - 4.5k
RAM - Corsair value RAM 2GB DDR3 1333 Mhz - 2.6k
PSU - Corsair CX 400W - 2.2k
HDD - WD Green 1 TB - 3.2k
UPS - Please suggest one - 3k
Cabinet - 1.5k
Since it is an office PC, budget is not that strict, can be stretched a bit.
Also suggest how this system should be cooled. Will the stock HSF suffice for the processor? I'll install two additional fans (1 Inflow 1 Outflow) & a hard disk fan if available.
The people who will install the cameras said AMD processors will hang in a 24 hour on system, so we should buy Core2Duo. what a joke
Old 04-06-2010, 11:02 PM   #2 (permalink)
Default Re: Buying a system for round the clock operation
Cabinet - 1.5k
bold marks should be checked:
1. how X2 555 runs cool?
2. that mobo is AM2+/AM3. so DDR2 only.
3. APC 650VA.
Old 04-06-2010, 11:39 PM   #3 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Go for MA785GMT-U2SH or UD2H etc. Both are DDR3.
Other's is fine. Check out what Sam suggested.
If you'are planning to run the proccy on stock cooler try to get some good cabinet's such as Zebby Bizli, CM Elite 310 etc. (Both are within your budget). Or just check for 2x80mm Fan and 1x120mm Fan at least.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now   Reply With Quote
Old 05-06-2010, 05:59 AM   #4 (permalink)
Cool Buddy's Avatar
3. APC 650VA.
would Biostar TA785G3 be a good option? I don't know much about motherboards & saw the options available on lynx-india.com.
I wrote phenom II X2 550 runs cool because AMD has been improving with every range of processors & Phenom II is their latest range. Besides, in a thread you only wrote that AMD Phenom II runs cooler than Athlon II
Old 05-06-2010, 06:19 AM   #5 (permalink)
pulsar_swift's Avatar
you got it wrong X6 runs cooler than X4. You can go with Phenom II if you have AC in the office during day time. AMD (Mostly Athlon II and few Phenom II) PCs in our office run non stop for months together. But in office AC is there for 12 hrs
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline   Reply With Quote
Old 05-06-2010, 10:43 AM   #6 (permalink)
if no gaming. its a good board.
also maybe i was pointing out X2 runs cooler than an X4. but do remember Phenom II X2 got 6Mb L3 cache & it still uses the default Athlon II cooler. so, if someone unlocks the 2 extra cores, that processor will run hot.
Old 05-06-2010, 02:26 PM   #7 (permalink)
Techie By Heart
mavihs's Avatar
don't go for Green for OS host! you can go for Seagate 1TB or WD 500GB Blue+WB 500GB Green.
Cabinet - 1.5k
increase your budget for the cabinet as you want 24hrs operation & for the cooling then yon need a good airflow!
i would say go for NZXT Gamma. Don't go for Elite in any case!
make it 1 inflow & 2 outflow. Also no need for HDD fan!
ROFL!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 05-06-2010, 02:34 PM   #8 (permalink)
any particular reason here. i seen you suggesting Green shouldn't be used as primary HDD. why?
Old 05-06-2010, 04:13 PM   #9 (permalink)
Techie By Heart
mavihs's Avatar
recently i heard people with Green where getting some probs(crash, HDD failure, etc) (only those people who had put the green as the OS host drive also green has bad performance as a OS host drive in general!
Old 05-06-2010, 04:25 PM   #10 (permalink)
thats strange. i heard about crashes only in WD Blue & Seagate. not came across even a single complain about WD Green.
Green performs around 15-20% slower than blue cause of reduced speed.
Old 05-06-2010, 04:32 PM   #11 (permalink)
Cool Buddy's Avatar
What do you mean by unlocking the 2 extra cores, please explain
Old 05-06-2010, 05:46 PM   #12 (permalink)
Phenom II X2 ---> X4 + 2 cores locked. so if those 2 cores unlock & are still in working condition, processor temp will rise significantly. now its upto you to experiment with these things.
Old 05-06-2010, 09:10 PM   #13 (permalink)
Cool Buddy's Avatar
wow, so essentially even Phenom II X2 is actually a Phenom II X4 & if we unlock the 2 cores somehow, we will have a X4 at the price of X2!
Old 05-06-2010, 09:17 PM   #14 (permalink)
yes. you not know about it? i just thinking, if AMD start selling faulty thubans as X2. unlock & voila. X6 at the price of X2.
well most X2s open to X3. & some lucky ones get it to X4 & even OC it.
Old 05-06-2010, 10:02 PM   #15 (permalink)
Cool Buddy's Avatar
how does one unlock the core? and what's the use of selling it as 2 core when it is actually 4 core? are they mostly faulty cores which are locked?
Old 05-06-2010, 11:23 PM   #16 (permalink)
just by turning a feature known as ACC (advanced clock calibration) in BIOS. AMD has removed it from their 8-series motherboard, but board manufacturers put their own ACC in. known as core unlocker (Asus), GT60 or something (biostar) etc.
in a X2 (Phenom II only, not Athlon II. they native dual cores), the cores are quality tested. if fault comes up, that core is locked. now the thing is that AMD's quality testing so high. even cores with minor defects can't pass. so, locked & sold as X2. in 2009 AMD used to have X3 also. but what happened actually is, as time passed Global Foundries manufacturing process improved. & so less defective processors were produced. as a result, AMD stopped selling X3s. instead locked 2 cores, even if only 1 is bad & sold it as X2.
i marked the 3 question you asked in bold letters. to access quick answers
Linux is a doomed operating system; here's how you can save it xitij2000 Open Source 30 15-07-2010 05:24 PM
System doesn't Resume! prankie Software Q&A 2 05-04-2010 03:24 PM
system boots but no display vickybat Hardware Q&A 2 19-03-2010 11:48 AM
Auto system boot for scheduled download!!!!!!!!!!! phreak0ut Tutorials 13 27-08-2007 06:12 PM
Boot INI Option Reference go4inet Software Q&A 5 18-10-2004 12:07 AM
