In google give the name of the cabby you have .From image select a picture with a side panel. draw a sketch in paintbrush for the side panel. or you can take a picture of your cabby and then do the job in system.
Now, draw that same sketch with a pencil on the side panel.go to a tin cutter (generally grill worker).Best Configuration within 30K
total cost ?
acrylic will be within 100 bucks.
no idea about silicon gel
how to make space for fans on the acrylic sheet?
just googled it.
i just want a transparent side panel how much will it cost
and cm cabbby was way easier to get than any other
nzxt was highly pricedand i don't want to go with a zebronics cabby
AMD Phenom x6 1055T @3.50ghz || MSI R6850 @925Mhz OC/PE || 2X2 GB RIPJAWS 1333CL8 || CM 460W REAL POWER ||Asus M5A97 EVO || Lancool PC-K62 || Sennheiser HD201+Fiio E5 || Logitech G400+Razer Golathius || Epson TX121 with CISS || Arch Linux ||
have you gone through the links provided to you. i have done modding in CM ELITE 310.
Originally Posted by saurabh_1e
thing else can be used against acrylic sheet.
can;t get you.
who will make holes in acrylic sheet
you do for yourself.
after you buy that sheet and design it, some wastage will come out. now make a screw driver hot and pierce it through the sheet(in the wastage part) first. or you can drill it from a carpenter keeping a thick cloth beneath so that it will not crack.
after all these are done you may go for lighting portion. i will tell you that after you finish the first part.
---------- Post added at 02:02 PM ---------- Previous post was at 02:01 PM ----------
[/COLOR]
Originally Posted by avichandana20000
i cannot find any pic of your cabby.
can;t get you.
not able to find acrylic sheet anywhere
can use simple glass instead
not able to find rubber u channel.
asked a grill cutter he will cut the side panel
this i am doing from my office. so for security reasons i will not be able to see the pics through any link. hence pls attach the pics with you message here only. anyhow i have googled it.
you need to keep both the channels for fan. and in that case you may draw like this.(file attached)
what is your idea?
hey aichvandana20000 , how much did it cost you to modify your cabby???? could you give link to that specific thread here???? me also thinking to do some creativity on my cabby....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
