Re: Router with multiple internet connection
if u r thinking of wifi router.. them most of the companies wont support this..
other Ethernet routers are available but too costly for home use..
u can do one thing.
u can connect one connection to a computer and then enable ICS and share internet..
and another u can connect it to wifi router.. and u can share wireless.
or if u r familiar with router firmware u can install dd-wrt or tomato firmware.
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
