Old 03-06-2010, 08:12 PM   #1 (permalink)
phil2097's Avatar
Default help me get a decent gaming rig under 30k
i need a gaming rig under 30k
this is a short idea of wat i need but its free to be edited .. . . .
amd phenom 555 BE
890gx motherboard
2gb ddr3
1gb or 512mb ddr5 gpu- 5650 or 5770
iball baby 360 cabinet wit 400w psu n 2 fan
acer lcd 20.5in
seagate baracuda 1tb hdd
lg dvd drive wit light scribe
if the budget is a pain dn i might add the gpu later n concentrate on the other stuff, cos i think d igp cn handle d games without bells n whistles rgt?
like i said thats my rough idea i need the best juice i can get 4m this budget
phil2097 is online now   Reply With Quote
Old 03-06-2010, 08:59 PM   #2 (permalink)
teh tech saviour!
saurabh_1e's Avatar
Default Re: help me get a decent gaming rig under 30k
AMD Phenom II 555be 5k
gigabyte GA-MA785GMT-US2H 5.5k
kingston 2*2GB DDR3 1333Mhz - 5.4k
WD Caviar Blue 500GB Hard Disk - 2k
sony DVD Writer - 1.1k
zebronics bijli- 1.7k
Corsair vx450 PSU - 3.8k
benq hd22.... 7.5k
total 32k
get this gfx later
msi hawk HD 5770 1GB GDDR5 graphics - 9.6k
AMD Phenom x6 1055T @3.50ghz || MSI R6850 @925Mhz OC/PE || 2X2 GB RIPJAWS 1333CL8 || CM 460W REAL POWER ||Asus M5A97 EVO || Lancool PC-K62 || Sennheiser HD201+Fiio E5 || Logitech G400+Razer Golathius || Epson TX121 with CISS || Arch Linux ||
saurabh_1e is offline   Reply With Quote
Old 04-06-2010, 12:12 AM   #3 (permalink)
amd phenom 555 BE
890gx motherboard
2gb ddr3
acer lcd 20.5in
little change:
Processor: Athlon II X3 435 2.9GHz @ 4k
Motherboard: Biostar TA785G3 HD @ 4.2k
Ram: A-Data 2Gb DDR3 1333Mhz @ 2.7k
Hard Disk: Western Digital 500Gb Blue @ 2.2k
Optical Drives: LG GH22NS50 @ 1.1k
Graphics Card: Sapphire HD5670 512Mb @ 5.4k
PSU: FSP Saga II 400W @ 2k
Cabinet: Cooler master Elite 310 or Zebronics Bijli (without PSU) @1.5/1.3k
Monitor: Benq G2020HD 20” @ 6.6k
Total: 29.9k.
your system is highly out of balance & also the choice is not good.
with 890GX based motherboard, you simply spending a lot of money on USB 3.0 & Sata 3.0. both you can add with a addon PCI card for about 1k.
also theres no card like HD5650. & if you combine HD5770 + a cheap bad iBall 400W PSU. your system will instantly die.
Old 05-06-2010, 02:04 AM   #4 (permalink)
Techie By Heart
mavihs's Avatar
Can you fill the below questionnaire so i can suggest you a good config!
1. What is your MAX budget?
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
3. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
4. Planning to overclock?
7. What resolution will the screen run at?
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 05-06-2010, 08:41 PM   #5 (permalink)
phil2097's Avatar
Originally Posted by Sam.Shab View Post
"your system is highly out of balance & also the choice is not good.
also theres no card like HD5650. & if you combine HD5770 + a cheap bad iBall 400W PSU. your system will instantly die."
i agree . . . . but i needed 890gx mobo 4 the hd4290 igp wit 128mb sidiport mem if im planin to go without the gpu 4 d time being seeing that is the case cos m already itching to invest . . . . cnt wait another 2months to save up
sata3.0 n usb 3 r not my concern cos frankly its still a while 4 d system to keep up rgt? if vfm is concerned i think if i get a 790gx and 890gx at the same rate then shouldn't i opt 4 the 890gx? then again wit 890fx or was it 790fx? the new mobo coming wats the performance and price index?
about the psu well im not planing to kill the pc but if i get one of those gpu that don't need the 6pin power connector, do i need more than 400w psu?
im not going 4 a total overkill but as i said a very tight budget, hopefully tryin to walk and talk with it
thnx 4 ur reply . . . .still tryin to figure out though
looking into ur suggestions
---------- Post added at 08:41 PM ---------- Previous post was at 08:12 PM ----------
well . . . . 30k
yes
--documents, movies, latest games (i can do without the bells n whistles), record n editing music
not yet, after a few months wn things slow down maybe
win xp most of the time, dual boot wit win7
1tb is enough
20inch lcd (1080p wil b gud but not mandatory) if the budget permits
between 5 and 7
nope. i will, wit sm geek pals
within this month
yes mostly but usb3 n sata6g can wait
keyboard, mouse, speakers
delhi. yes
- suggest a good gpu i think 5series will b gud under 9k n it can wait if budget does not permit
- mobo wit igp like 890gx is prefered cos of the 128mb sideport mem igp (hd4290 i believe rgt?) cos without the gpu 4 1 or 2 months it gona kill me!!!!
- can i add 3gb ddr3 ram or is there? i dont think so (only in trichannel mode i think) so im left wit 2gb ddr3 ram wit 32bit OS rgt?
Home PC for very basic gaming within 30k - please suggest bippukt Hardware Q&A 13 26-03-2010 08:54 PM
Please suggest a gaming desktop for around 30k abyss88 Hardware Q&A 5 23-03-2010 06:45 PM
Please help in building a new rig: Urgent falling Hardware Q&A 36 07-02-2010 02:25 PM
Roccat Gaming Gear ! GO SET THE RULES COMING IN INDIA predatorvjisback Hardware Q&A 0 20-01-2010 09:16 PM
Gaming in India—entering the next level Simple_Graduate Gamerz 3 09-04-2007 03:46 PM
