Old 03-06-2010, 07:18 PM   #1 (permalink)
Smile New MoBo and processor
I am thinking of updating my cpu for a new one. Please suggest a combination of mb processor ram and graphics card within 10000-15000. my uses are limited to office work and midlevel gaming
vishaljamuar is offline   Reply With Quote
Old 03-06-2010, 08:21 PM   #2 (permalink)
The Assassin
Cybertonic's Avatar
Default Re: New MoBo and processor
AMD phenom ii x3 435 - 4k (a bit difficult to find but u can order it from techshop.in)
Gigabyte GA-MA74GMT-S2 - 3k
2 GB DDR3 from A-data or zion - 2.5k
HD 5670 1GB - 6k
Total- 15.5k (it will fit into your budget if u get good street deals)
Cybertonic is offline   Reply With Quote
Old 03-06-2010, 11:50 PM   #3 (permalink)
Processor: Athlon II X3 435 2.9GHz @ 4k
Motherboard: Biostar TA785G A3 @ 3.7k
Ram: A-Data 2Gb DDR3 1333Mhz @ 2.6k
Graphics Card: Sapphire HD5670 512Mb @ 5.3k
PSU: FSP Saga II 350 Watts @ 1.5k
total: 17.1k. skip the PSU if you having a good PSU. BTW what PSU you having?
Old 06-06-2010, 05:59 PM   #4 (permalink)
The Assassin
Cybertonic's Avatar
oops srry
i thought it was phenom ii x3 as techshop.in is listing it as phenom
Need advice on choosing mobo for phenom 9550 Quad achtung Hardware Q&A 6 02-06-2010 06:48 PM
Pl suggest good processor + mobo HRISHIG Hardware Q&A 6 03-01-2007 07:59 PM
need a mobo with support for 478 socket P4 processor steelcold Hardware Q&A 2 12-11-2006 06:09 AM
Best AMD Processor & MoBo Combination for my new PC? Ramstrong Hardware Q&A 20 27-10-2006 06:50 PM
Which mobo and processor.... jay4u Hardware Q&A 1 09-04-2006 12:21 AM
