03-06-2010, 02:21 PM
9400GT or HD4350????
hi i am upgrading from P4 2GHz, 768MB RAM with FX5500 256MB AGP to
pentium dual core 2.6GHz [ AMD athlon II X2 245 if it is available in local market]
ASUS intel chipset based board [compatible mobo if i use AMD processor]
2GB DDR II RAM
and a cheap graphic card.
since i am in class 12 and i m upgrading using my pocket money, i need cheapest components and i dont want future proofing since i will buy a new PC next year.
currently only 9400GT and 8400GS and ASUS EAH4350 is available in local market so i cant buy newer HD5XXX series or GT2XX series.
please suggest one from
9400GT 1GB
4350 1GB
i want to play games released in 2008 or before and i am happy with 800X600 resolution with low graphics.
which one from 9400GT and HD4350 will give more performance?
please dont suggest other card since only these two are available here and i cant buy online.
03-06-2010, 03:20 PM
BLUE IS THE COLOUR
Re: 9400GT or HD4350????
Get E5400 or X2 245 and 9400GT.
9400GT is more powerful than HD 4350
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
03-06-2010, 04:27 PM
Excessive happiness
Bump up your budget a lil bit and get 9500GT. Its much better. But among the two you mentioned, 9400GT seems to be a good option.
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
03-06-2010, 10:20 PM
yes, 9400 GT is more powerful due to its higher memory bandwidth. But since you would be buying a new PC next year, you could do away with the graphics card and opt for a good motherboard with capable IGP
03-06-2010, 10:57 PM
not needed. 9400GT 1Gb = 9500GT 512Mb in price.
good point. get a good motherboard instead of spending on cheap & bad graphics card
04-06-2010, 01:04 PM
i cant buy 9500GT as i said, only 9400GT and HD4350 is available. i will not buy mobo wid good IGP since i will assemble new PC by late 2011 or early 2012. and i am upgrading without telling anyone in my family
few days ago, i hunted for 9500GT [my friend wanted a cheap card and i suggested 9500GT] but it is not available in any shop. only 9400GT and HD4350 is available and my friend bought HD4350. he is happy and playing games like burnout ultimate box and NFS undercover and GTA4.
they are selling other cards at too high price. 9800GT for Rs9k and HD5770 for 11500/-.
so please suggest one from 9400GT or HD4350
04-06-2010, 01:11 PM
Legendary Darknight
9400 is the one to go among the above given cards..
04-06-2010, 04:10 PM
see friend, you want game thats why you going after a card, but thing is, a 9400GT or HD4350 is lowest end model of each section (ATI & Nvidia). so getting a good IGP based motherboard & skipping the graphics card looks a better idea to me. if you look at Tom's Hardware Graphics Card Hierarchy Chart, you'll find this:
Nvidia:
Discrete: 6600 GT, 6800LE, 6800 XT, 7300 GT (DDR2), 8500 GT, 9400 GT
Go (mobile): 7600 (128-bit)
ATI:
Discrete: 9800 XT, X700 PRO, X800 GT, X800 SE, X1300 XT, X1600 PRO, HD 2400 XT, HD 4350, HD 4550, HD 5550
Mobility: X800, 3470, HD 5470 (DDR3), HD 5430
Integrated: HD 3300
so a motherboard based on 785G or 790GX will give roughly same performance as HD4350 or 9400GT. than why are you spending 3k extra? simply get a 4k motherboard based on 785G or 790GX & you are done. no 9400GT.
hope i cleared why you better with IGP. & with the saved money get a Athlon II X3.
04-06-2010, 08:48 PM
problem is availability. they dont sell cheap 790GX or 785G. only few AMD boards are available with poor onbaord graphics like geforce 7025.
04-06-2010, 09:53 PM
Where do you stay?
08-06-2010, 09:28 AM
gorakhpur.
and i cant buy online so dont suggest
i will try to order GT220 on local shops. but there is 80% chance that i will not get it. so please suggest one from 9400GT and HD4350
08-06-2010, 10:33 AM
gorakhpur.
pick up 9400GT but 512Mb. as 1Gb memory is unnecessary on such a low end card.
08-06-2010, 01:33 PM
Pro/An---tagonist xD
I still feel that a 785 board will be a better option.
My 785 is now running GTA4. xDD Not ultra high settings but satisfactorily smooth in low settings.
\m/
Amd athlon II X3 435 unlocked to Phenom II X4 B35 8-) | MSI 785 G-E53 | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz| Seagate 500 gb 7200.12|
09-06-2010, 08:27 AM
@above: those boards are not available in my area [but i will try to find again]
so i need low end card. and my budget is tight.
also can anyone tell me compatibility of AMD athlon X2 CPUs with AM2, AM2+ and AM3 socket? i dont know too much about AMD sockets. [so i am planning to buy LGA775 mobo with pentium dual core E5300 2.6GHz]
i have to buy motherboard this monday so tell me ASAP
09-06-2010, 08:59 AM
dude amd x2 with 9400gt will go like rocket .....check out 9400gt card review on digit feb-April issues .... savvy's! bye!
09-06-2010, 10:34 AM
You don't need to know much about sockets to buy a mobo proccy combo. Most people don't even know what is a socket & still they use a PC. Where did you get the idea that since you do not know much about AMD sockets, you should not buy it? If you buy a C2D at this point of time, you'll regret it later. Buy a Mobo with socket AM3 and it'll support Athlon II & Phenom II CPUs, you can even change your proccy later on without changing the mobo.
17-06-2010, 05:39 PM
i bought intel pentium dual core E5300 2.6GHz . they had AMD athlon II X2 240, but they warned me that i should buy processor and motherboard together due to lack of availability of amd boards. so i bought intel pentium dual core. i will buy mobo, and RAM next month.
now i have DROPPED PLAN FOR 9400GT or HD4350.
GT220 is just arrived here and i am going for it. @ Rs 5500/- [point of view GT220 1GB]
only these cards are available:
8400GS 512mb Rs2400/-
9400GT 1GB 3500/-
HD4350 1GB 3400/-
HD5770 1GB 11,500/-
9600GT 1GB 7500/-
9800GT 1GB 9500/-
GT220 1GB 5500/-
9600GT,9800GT and HD5770 are out of my budget. so i am going for GT220. is this good?
no other options are available this time like GT240, or other ATI card.
17-06-2010, 08:36 PM
prices you mentioned are tooooooo high. DO NOT GO FOR GT220 AT SUCH A HIGH PRICE. I WARN YOU DONT DO SOOOOOO. JUST WASTING MONEY.
BTW any specific reason u cant order online..i urge you to skip the idea of buying from your local store until you find good prices.
i didnt understood your statement--
"but they warned me that i should buy processor and motherboard together due to lack of availability of amd boards"
17-06-2010, 09:45 PM
#19 (permalink)
thats why i didn't commented on those prices.
the shopkeepers selling motherboard + proccy as a bundle as motherboard availability is low. if you get a AMD proccy, it'll be trouble finding a suitable motherboard for it.
18-06-2010, 07:56 AM
#20 (permalink)
But ultimately he didn't buy the mobo, he only bought the processor, so he could have done that with an AMD proccy too.
5500 for GT220, I don't know why one would go for something which is worth 4000 at 5500, even if availability is a concern
18-06-2010, 10:24 AM
#21 (permalink)
he brought proccy alone. but as Intel motherboards are available, he can simply get one.
GT220 = HD4670, or little slower in performance. also its overpriced. OP's price is super overpriced.
18-06-2010, 11:31 AM
#22 (permalink)
Traveling to Kolkata & buying the PC would have turned out cheaper even with the traveling costs included and you could have bought something better than pentium dual core (I had even forgotten that there was one Intel's dual core option before the core processor's came along  ), would have just needed parents permission & 3 day's time
18-06-2010, 11:57 AM
#23 (permalink)
Intel going to launch a few more Dual Cores today & in coming months (LGA775 based). more here: Intel getting ready to launch four sub $150 desktop processors.
20-06-2010, 06:36 AM
#24 (permalink)
i cant buy online coz i dont have bank account. i can only pay throgh moneyorder or bank draft. any site avaialbe which can accept draft/moneyorder?
is it safe? i have never used draft/moneyorder to buy stuff online
it is point of view GT220 1GB DDR3 @Rs5500/- what is its cost in other part of india?
i thought same when i saw its high price. i can buy a zotac GT240 cheaper than that. but due to lack of availability. i planned to buy GT220.
also note that i still use 17 monitor and i am happy with 1024X768 resolution. i play @ 800X600 this tine
20-06-2010, 11:23 AM
#25 (permalink)
Excessive happiness
If thats the case then you would better buy a HD4670 1GB which kicks the GT220 out of the league
PS Request
20-06-2010, 09:02 PM
#26 (permalink)
as i said AVAILABILITY is main concern. i have already told u that i have only 3 options here.
9400GT
HD4350
GT220
21-06-2010, 01:19 PM
#27 (permalink)
Excessive happiness
9400GT
HD4350
GT220
So what, deposit the money in rahul- ITWares guy account and purchase the product. Now dont tell me that there is no bank in your city.
Its always wise to get the better option and among the three you mentioned nothing is worth the money. So go for what i've said
The URL is TheITWares -TheITwares Ecommerce
PS Request
21-06-2010, 04:34 PM
#28 (permalink)
i cant open bank acc. i am still 17 and i dont have bank acc. :O
looks like i dont have any options left. i will go for GT220.
25-06-2010, 05:53 AM
#29 (permalink)
is iball 400W is good for GT220? i m in a tight budget. so i cant afford CM or Corsair etc.
25-06-2010, 09:16 AM
#30 (permalink)
why dont you ask your father. he must be having a bank account.
DONT WASTE YOUR MONEY!!!!!
