Old 03-06-2010, 07:07 AM   #1 (permalink)
Cool Buddy's Avatar
Default Hard disk is getting too hot
For the last few days, my hard disk is heating too much. Whenever I check the temperature, it is around 51-52 degree Celsius even if there has been minimum hard disk usage. When I switch on the PC it is around 40 degrees and gradually rises to around 51-52 in half an hour. I cleaned my cabinet yesterday, CPU fan & SMPS fan are working properly. What could be the reason?
Old 05-06-2010, 05:39 PM   #2 (permalink)
Cool Buddy's Avatar
Default Re: Hard disk is getting too hot
no replies?!!!
Old 05-06-2010, 05:43 PM   #3 (permalink)
BE FREE
which hdd is that, what is your ambient room temperature and does the hdd run smoothly or do you hear any abnormal noise?
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline   Reply With Quote
Old 05-06-2010, 06:08 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Mine run at those temperatures. It is fine.
asingh is online now   Reply With Quote
Old 05-06-2010, 07:02 PM   #5 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
HDD's gets hotter more than other components coz of number of times read/write operation which makes internal mechanical parts moving heavily. Don't worry for HDD's this temp is normal.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now   Reply With Quote
Old 05-06-2010, 09:16 PM   #6 (permalink)
Cool Buddy's Avatar
I have a seagate 250 GB HDD almost 3 years old (8 MB cache). I was worried about those temperatures because games are crashing & even firefox crashes many times. Besides the 500 GB WD green I bought recently & put inside a closed case (using as external) never goes beyond 43 degrees after half an hours usage.
The ambient room temperature should be around 33-34 degrees in afternoon-evening & 30-31 degrees in morning. I do not have gfx card, so inside of the cabinet is not that hot. even the processor is just 2.0 Ghz AMD Athlon X2. Also, my friend's HDD (same model) is reaching just 42-43 degrees even after an hours usage. His house is close, so temperatures are similar.
Those are the things which caused me to worry. But now that I know that it's not that high, I'm not worried that much. Also I have a backup of almost everything i my new HDD, so even if it fails I won't lose data & it is also under warranty. So no worries.
---------- Post added at 09:16 PM ---------- Previous post was at 09:15 PM ----------
Thanks everyone
Old 05-06-2010, 11:44 PM   #7 (permalink)
Simply a DIGITian
Dont worry....External HDD's temp. that you stated are normal. Intenal HDD spins much more than an external HDD(coz for each operation your hdd in spinned). So no need to worry.
But if you are curious about why your's friends HDD temp is low may be you should try defragmenting the HDD. That will less spinning count and may be the temp too
Old 06-06-2010, 07:18 AM   #8 (permalink)
BE FREE
Thanks everyone
just install - SeaToolsforWindowsSetup-1201 from sgt site and check for any failure chances of hdd, and also games should crash only if the cpu temp or gfx temp overshoots.
External Hard disk failure pls help dilipc Hardware Q&A 3 08-04-2010 01:09 PM
Certified Repaired Hard Disk anni Hardware Q&A 3 01-04-2010 04:42 PM
Hard Disk girishrn Hardware Q&A 5 25-03-2010 07:43 PM
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
Improving Vista's Hard disk performance gxsaurav Hardware Q&A 6 16-03-2007 11:23 AM
