Old 02-06-2010, 04:41 PM   #1 (permalink)
achtung's Avatar
Arrow Need advice on choosing mobo for phenom 9550 Quad
Hi,
I have one AMD phenom 9550 (Quad) processor.
Please help me to find a suitable mobo for the same...
My budget is within 5 - 6K
##aChTuNg##
Experience is what a comb gives you after you lose your hair.
achtung is offline   Reply With Quote
Old 02-06-2010, 05:22 PM   #2 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: Need advice on choosing mobo for phenom 9550 Quad
Biostar TA880GX / TA890GX / TA790GX a3+
VarDOS is offline   Reply With Quote
Old 02-06-2010, 05:49 PM   #3 (permalink)
achtung's Avatar
Many thanks Varad...
I think my phenom 9550 fits on AM2+ socket..
If I purchase a board of AM3 socket.. will my processor fit in that?
I meant to ask if whether AM3 socket is downward compatible with AM2+ processors?
##aChTuNg##
Old 02-06-2010, 05:59 PM   #4 (permalink)
you'll need AM2+ motherboard. AM3 won't as its pin incompatible.
Old 02-06-2010, 06:16 PM   #5 (permalink)
achtung's Avatar
Thanks a ton Sam...
another thing.. if a mobo has built in ATI Radeon HD 3300 Graphics chipset in it.. do you think that it is sufficient for most of the common modern games and mini/micro HD movies? Or does it need a graphics card with it..?
##aChTuNg##
Old 02-06-2010, 06:24 PM   #6 (permalink)
Thanks a ton Sam...
my pleasure buddy
HD3300 i.e. based on 790GX is sufficient for most games if played in 1024X768 resolution or little higher. even Crysis will give playable FPS if you turn enough settings down. but anything higher or if you planning game on 20" or bigger monitor, a graphics card of midrange or upper lowend seriously recommended.
Old 02-06-2010, 06:48 PM   #7 (permalink)
achtung's Avatar
my pleasure buddy
Sam.. You just made my day man..
Kudos..
Many thanks to Varad as well...
##aChTuNg##
Is my Mobo limiting my Proccy's performance? ajai5777 Hardware Q&A 7 28-02-2010 02:17 AM
How to select a boot first device temporarily in MSI mobo? ajai5777 Hardware Q&A 0 21-02-2010 10:56 PM
Help needed in choosing the right processor and mobo swaroop123 Hardware Q&A 3 19-03-2008 03:02 PM
Need suggestions for mobo upgrade gulgulumaal Hardware Q&A 4 12-11-2007 06:17 PM
Recommend best Mobo for C2D and Quad C2D in price range of 9K to 14K ramu Hardware Q&A 3 17-06-2007 07:08 PM
