Old 02-06-2010, 11:38 AM   #1 (permalink)
Default want to know more about cpu coolers
well i know the importance of cpu cooling but dnt really no how coolers help nd if i need one or not. i dnt overclock rather i dnt know how to overclock i would if knew how to ... so i m begining wid da first step dat is to cool my pc ...plz help me decide wat cooler to buy nd my budget is not more than 6K
plz help guys nd plz suggest some software dat will help me monitor my cpu temperature .. thnks a ton
guru280789 is offline   Reply With Quote
Old 02-06-2010, 12:41 PM   #2 (permalink)
teh tech saviour!
saurabh_1e's Avatar
Default Re: want to know more about cpu coolers
first tell your config
then if you plan to overclock (oc)
for temp mngmnt
speed fan
hw monitor
real temp for amd
and lots more just google up
cpu z for computer specifications.
AMD Phenom x6 1055T @3.50ghz || MSI R6850 @925Mhz OC/PE || 2X2 GB RIPJAWS 1333CL8 || CM 460W REAL POWER ||Asus M5A97 EVO || Lancool PC-K62 || Sennheiser HD201+Fiio E5 || Logitech G400+Razer Golathius || Epson TX121 with CISS || Arch Linux ||
saurabh_1e is offline   Reply With Quote
Old 02-06-2010, 01:06 PM   #3 (permalink)
Super Moderator
asingh's Avatar
See, if you are not overclocking the CPU to extreme points then stock HSF (heat sink fan) are fine for you. Also is is important to know what system configuration you have. Something similar to the signatures we carry on our posts here. Reason being many parameters come into play. Also the motherboard clearance (NB heat sinks, DIMM sockets) also are important. OEM HSFs can be big. For your budget you could probably get the best OEM HSF available.
For example see this:
Noctua NH-D14. This is around ~4.8K. And available in India. It is probably one of the best air coolers available. Something like this is procured if you are going for 35-40% system overclock. Extreme. Else there are HSFs available for lower range. Hyper 212 (Rs. ~2.8K) is good also.
asingh is online now   Reply With Quote
Old 02-06-2010, 01:58 PM   #4 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Man you have decided to cool yor proccy even before you overclock it.Its not like that.Most multicore CPU's get 15-20% OC in stock HSF.First you OC your proccy in stock and check temperatures in stress tests.If its in safe limits, you dont even need a cooler or you can get one to push your CPU little more.
My Athlon II X4 630 is running @ 3.3GHz in stock.It even touches 3.4GHz.But in stress tests its temperatures go higher with out crashes.So I am going to get a cooler to bring temperatures to the safe level and for a little more OC.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 02-06-2010, 02:07 PM   #5 (permalink)
pulsar_swift's Avatar
Hyper 212 Plus is available @ 1.8K + shipping from MEDIAHOME and PRIMEABGB
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline   Reply With Quote
Old 02-06-2010, 02:16 PM   #6 (permalink)
k luks like i need a cooler only if i overclock...
can u tell me wat does overclocking mean m new to this so nd m ill informed... does overclocking include bios tweaking or does it include hardware tweaking as well....and wat r the advantages nd the side effects ...
AMD phenom IIx4 925 2.8ghz | asus m2n68-am plus | ati radeon hd 4850 | cm600 watt extreme power plus | 1Tb samsung | 160gb seagate | SONY-DVD-R | zebronics warhawk
Old 02-06-2010, 02:20 PM   #7 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Will a hyper TX3 do anything good for my proccy?
I have read somewhere that someone got 4GHz in Athlon II X4 630 with hyper TX3.I have read his posts and planned to get hyper TX3 also its much cheaper than hyper 212
Old 02-06-2010, 03:49 PM   #8 (permalink)
Super Moderator
asingh's Avatar
Guys if going for OEM HSF, make sure it is bolt down. Nothing beats this. Push-pin is totally useless.
Old 02-06-2010, 08:07 PM   #9 (permalink)
@asigh:the 212+ is Rs1.8k in bangalore
Win hardware worth 11k!!
rajan1311 is offline   Reply With Quote
Old 02-06-2010, 09:41 PM   #10 (permalink)
Super Moderator
asingh's Avatar
Was talking about the Hyper 212 not (+) model, which is more expensive than the newer Hyper 212, being twin tower. Hyper 212+ is HDT.
Old 02-06-2010, 09:57 PM   #11 (permalink)
Here is the URL
http://www.primeabgb.com/index.php?p...mart&Itemid=53
Old 03-06-2010, 04:01 PM   #12 (permalink)
Super Moderator
asingh's Avatar
I know that about the Hyper 212+, so what you trying to get at..?
Old 03-06-2010, 04:06 PM   #13 (permalink)
i am saying its available @ Rs 1850 +shipping. You were saying its Rs 2.8K na ?
Old 03-06-2010, 04:47 PM   #14 (permalink)
Super Moderator
asingh's Avatar
That is the Hyper 212. Not the Plus model. There is a difference between the two, as I mentioned initially.
Old 03-06-2010, 06:05 PM   #15 (permalink)
but they wrote 212 plus in the site bro. as you said, its also a DHT.
Old 03-06-2010, 07:32 PM   #16 (permalink)
Super Moderator
asingh's Avatar
Okay, lets make it clear. There are two models of the Cooler Master Hyper 212 series.
Model 1: Hyper 212 : Cost 2.8K (or 2.4K, but for sure more expensive than the (+) model)
Model 2: Hyper 212+ : Cost 1.8K
Model 1 is the older model, more expensive than model 2, and is dual tower, and non HDT. THIS IS the model I was talking about being ~2.8K.
And it looks like this:
Model 2 is the newer model, and cheaper being single tower, but is HDT.
The reason I do not recommend this cooler is because it has a flaw on the contact surface.
See this image.
The direct contact pipes leave air gaps. Of course they will need to be filled with TIM.
Old 03-06-2010, 07:45 PM   #17 (permalink)
Ok got it now.thanks for the illustration bro. Hyper 212 also had heat pipes. If its not touching the CPU, how will it cool it.
Old 03-06-2010, 07:49 PM   #18 (permalink)
Super Moderator
asingh's Avatar
Well the heat pipes run between the cpu cooler header, so they transmit heat from the cpu cooler contact surface. Most coolers are of this design, non HDT.
Old 03-06-2010, 07:58 PM   #19 (permalink)
whats ur opinion on CM V8 , scythe mugen 2, xigmatek thors hammer ?
Old 03-06-2010, 10:25 PM   #20 (permalink)
Cool Buddy's Avatar
Firstly, your processor already has a cooler, you will need to upgrade it only if you overclock. Bsic coolers blow air on the CPU so that cool fres air keeps coming in and absorbs the heat from the CPU. coolers with copper pipes absorb heat from the CPU and release it outside. So if you overclock within 10-15%, the cooler that you already have, which is referred to as stock HSF (Heat Sink Fan), will suffice.
Old 03-06-2010, 10:54 PM   #21 (permalink)
CM V8 ---> huge.
scythe mugen 2 ---> nice one
xigmatek thors hammer ---> name says it all. & is also very expensive. & i read, don't ship with any fans.
Old 03-06-2010, 11:01 PM   #22 (permalink)
i am fida over the looks of CM V8.
Old 03-06-2010, 11:11 PM   #23 (permalink)
Super Moderator
asingh's Avatar
Well these are all good coolers in their class. All are bolt down, and only the Thor Hammer is HDT.
Though I would place them is performance (ascending):
CM V8 : Thors Hammer : Scythe Mugen
Again this is based on my reading about these. For sure CM V8 is the lowest cause its fan does not do the job, though the architecture, 4 layered towers is the best. Scythe Mugen has the best heat pipe system, where as Thor is HDT.
My choice is with the Noctua NH-D14, whose link I put on the first page of this thread. It is expensive, a bit shy of 5K. (Expect a review soon..hint hint).
Old 04-06-2010, 01:15 AM   #24 (permalink)
Techie By Heart
mavihs's Avatar
Noctua NH-D14 > Thermalright Venomous X > Others
---------- Post added at 01:15 AM ---------- Previous post was at 01:14 AM ----------
But its huge!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 04-06-2010, 07:01 AM   #25 (permalink)
Ahaa. So Asigh wil purchase it soon. I would love to read that review
Old 04-06-2010, 09:55 AM   #26 (permalink)
Super Moderator
asingh's Avatar
All ready have. Just need time to install it. Currently away from Delhi, am at my home town. Will put it in next weekend. Yes, it is huge. Will put up a good review.
Old 04-06-2010, 01:26 PM   #27 (permalink)
already have? you never passed a single word about it. when you bought? or is it a gift from someone?
Old 04-06-2010, 01:52 PM   #28 (permalink)
Super Moderator
asingh's Avatar
Purchased on my own..no gift....! Did not pass any word, cause cannot install it as of now. Have to wait at least another 8-9 days. During week days, I go not get enough time. So one I install it, will put in a full review. I got it last Saturday from itwarez (Mumbai) -- online+courier.
Old 04-06-2010, 03:02 PM   #29 (permalink)
how much did it cost? still very nice buy, congrats.
Old 04-06-2010, 03:12 PM   #30 (permalink)
Why did you buy it from ITWAREZ ? It was not available from MEDIAHOME ? Or was it a special deal ? What was the final landed price ?
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
Please List Basic C2D / Dual Core Overclocking Tips Choto Cheeta Overclocking 101 18-12-2007 09:31 PM
Nokia Processors - Hope its useful! solomon_paulraj Mobiles and Tablets 4 31-10-2007 02:57 PM
