Old 01-06-2010, 09:38 PM   #1 (permalink)
teh tech saviour!
saurabh_1e's Avatar
Default hd 5670 x 2 on cm real 460 watts
Will Two HD 5670 will work on cm real power 460 watts
with phenom x 1055t
msi 890gx
4 gb gskill ddr3 ram
2 x hdd
1 x odd
for crossfire do you need some extra cables or something else ?(learned from somewhere one graphic card should be master this is confusing me)
according to me
procy 150 w max
mobo + hdd + odd =75w
gfx 150 w max
total = 375w
and what will be cost of sapphire hd 5670 will two of them will be under 10.5k
i want a crossfire so don't recommend 5770 or any other single gpu.
AMD Phenom x6 1055T @3.50ghz || MSI R6850 @925Mhz OC/PE || 2X2 GB RIPJAWS 1333CL8 || CM 460W REAL POWER ||Asus M5A97 EVO || Lancool PC-K62 || Sennheiser HD201+Fiio E5 || Logitech G400+Razer Golathius || Epson TX121 with CISS || Arch Linux ||
saurabh_1e is offline   Reply With Quote
Old 01-06-2010, 10:12 PM   #2 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Default Re: hd 5670 x 2
It doesnt need a connector.It outperforms a single HD 5770.
But I wont recommend it.Because its the waste of a crossfire.Get a HD 5770 now and add another HD 5770 in future.Thats the best way to go.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 02-06-2010, 12:32 AM   #3 (permalink)
Techie By Heart
mavihs's Avatar
Default Re: hd 5670 x 2 on cm real 460 watts
any specific reason you want to go for CF?
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 02-06-2010, 12:38 AM   #4 (permalink)
+1. add 1 more point. crossfire not very efficient, in compare to SLI. so go for a single HD5770.
Old 02-06-2010, 07:53 AM   #5 (permalink)
teh tech saviour!
saurabh_1e's Avatar
Wanted to crossfire this time.
cannot crossfire 5770 because nor my psu allows me neither my budget.
will buy one 5670 right now and one afterwards or .............just a single gpu 5770 after sometime.
Old 02-06-2010, 08:47 AM   #6 (permalink)
better get a single HD5770 in a latter time. that will be better.
for now OC IGP & check how much fast games run.
Old 02-06-2010, 08:55 AM   #7 (permalink)
teh tech saviour!
saurabh_1e's Avatar
Unhappy Re: hd 5670 x 2
okay thanks everyone will wait for 5770
and one more query ?
2 x 5770 on cm 460 watts not possible na
Old 02-06-2010, 09:07 AM   #8 (permalink)
1 X HD5770 possible at max.
Old 02-06-2010, 09:30 AM   #9 (permalink)
Super Moderator
asingh's Avatar
That is contestable now...! Xfire scales quite well, specially when gaming >= 1920 x 1080.
asingh is online now   Reply With Quote
Old 02-06-2010, 09:42 AM   #10 (permalink)
so scenario has changed. heard a ton that Xfire not able deliver much good compared to SLI in majority of games.
Old 02-06-2010, 10:36 AM   #11 (permalink)
pulsar_swift's Avatar
I also plan to do the same. Have Hd5670 right now. I will add one more HD5670. I presume VX450 should drive this crossfire. Just want to crossfire for the heck of doing it
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline   Reply With Quote
Old 02-06-2010, 11:25 AM   #12 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
no.....stick to this:-
MSI HD5770 HAWX 1GB GDDR5 @ 9.6k
comp@ddict is offline   Reply With Quote
Old 02-06-2010, 11:28 AM   #13 (permalink)
Super Moderator
asingh's Avatar
Do read this. The Xfire delight is HD5770. They kill a 5870 even..! But remember guys, for Xfire please be on full HD, else it is useless.
Old 02-06-2010, 12:06 PM   #14 (permalink)
teh tech saviour!
saurabh_1e's Avatar
problem is i want to crossfire which is possible only with 5670 because 5770x2 costly and my psu is a limitation.so will be going with 2 x 5670 and this is all for fun man!
even a 5670 will suffice my need
just want to try this also.
Old 02-06-2010, 12:58 PM   #15 (permalink)
you answered your own question. if a HD5670 suffices for now. take a HD5770 so it'll be enough for a couple of years (provided you don't go HD gaming).
if the above point valid for you, why asking about Xfiring 2 HD5770. thats a overkill for both you & your PSU.
Old 02-06-2010, 01:03 PM   #16 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Man..you are doing a gr8 mistake.Just buy a HD 5770 for now.Then in future
after a long time when you get budget sell your PSU and buy a HD5770+PSU
Otherwise you are wasting your money in 2X 5670.
Old 02-06-2010, 01:05 PM   #17 (permalink)
teh tech saviour!
saurabh_1e's Avatar
i asked about 2 x 5770
because i just wanted to something new (xfire new for me) just doesn't require even two 5670 just for fun.
my thread started only asking if 2 x 5670 will run on cm 460
but it reached till here
Old 02-06-2010, 01:09 PM   #18 (permalink)
use the cooler master PSU calculator & decide yourself.
others advised not to follow your plan cause you'll be the one having a loss.
Old 02-06-2010, 01:15 PM   #19 (permalink)
teh tech saviour!
saurabh_1e's Avatar
okay yaar will get one 5770 after sometime
how can i defy td forum
Graphics Cards related queries here. geek_rohit Graphic cards 14632 Today 09:03 AM
CheapCPU & CostlyGPU VS CostlyCPU & CheapGPU emmarbee Graphic cards 52 07-06-2010 12:27 AM
Upgrade problem plz help. ajai5777 Hardware Q&A 56 14-05-2010 05:59 PM
Radeon HD 5450 Delivers DX11, Eyefinity at $50 topgear Technology News 0 05-02-2010 06:07 AM
