Old 01-06-2010, 05:14 PM   #1 (permalink)
avichandana20000's Avatar
Default Question about upgrading RAM .
Hi all,
I have a system with the following configuration.
Phenom ii X4 955 BE.
Asus m4a78te 790gx (4x dimm , max. 16GB, DDR3 1600 (o.c.) / 1333 / 1066mhz, ECC & Non-ECC Unbuffered)
Ram Transcend Jet Ram 2gb 1333(single piece) jm1333klu-2g
Questions
1)Can I attach another 2GB 1333Mhz from Corsair? Will it match? If yes please, suggest the model number.
2) Can I attach 4GB 1600 Mhz (2x2gb) from Corsair altogether?
*Mod Edit = FilledVoid *
avichandana20000 is online now   Reply With Quote
Old 01-06-2010, 05:24 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Serious sam,sorry, ram
Originally Posted by avichandana20000 View Post
I HAVE PHENOM II X4 955 BE.
MOBO ASUS M4A78TE 790GX
(4X DIMM , MAX. 16GB, DDR31600(O.C.)/1333/1066mHZ, ECC & NONECC UNBUFFERED)
RAM TRANSCEND JET RAM 2GB 1333(SINGLE PIECE) JM1333KLU-2G
1)CAN I ATTACH ANOTHER 2GB 1333 FROM CORSAIR? WILL IT MATCH? IF YES SUGGEST THE MODEL NUMBER.
2) CAN I ATTACH 4GB 1600 Mhz (2X2GB) FROM CORSAIR altogether?
Yes u can...coz ur mobo supports it...but make sure they r of same frequency
Old 01-06-2010, 05:25 PM   #3 (permalink)
Democracy is a myth
rhitwick's Avatar
That is the most misguiding thread title ever.
And yes u can attach another 2GB 1333 RAM module.
As it says 4X DIMM slot, u can attach another 3 RAM modules.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline   Reply With Quote
Old 01-06-2010, 05:26 PM   #4 (permalink)
Originally Posted by karanth85 View Post
yes u can...coz ur mobo supports it...but make sure they r of same frequency
how to check that frequency?
Old 01-06-2010, 05:28 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
u can check while booting in BIOS post screen....
or u can use 3rd party tools such as CPU-z or Everest..
---------- Post added at 05:28 PM ---------- Previous post was at 05:27 PM ----------
Ya i thought it abt the old game 'Serious Sam'
Old 01-06-2010, 05:34 PM   #6 (permalink)
Democracy is a myth
rhitwick's Avatar
Cool Re: Serious sam,sorry, ram
and
If the specs are written correctly ur MOBO sure supports RAM modules starting from anything to 1600MHz max.
As u already own one 1333MHz module buy one of same frequency, not necessarily of same company though.
Old 01-06-2010, 06:31 PM   #7 (permalink)
Super Moderator
asingh's Avatar
First of all such a stupid thread title. Second query is posted in all capitals. Hurts the mind and eyes.
asingh is online now   Reply With Quote
Old 01-06-2010, 06:50 PM   #8 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Default Re: Question about upgrading RAM .
Hi Avichandana2000,
Try to keep your post related to the title or vice versa. Ive made some changes to the post to make it more appealing I guess. Take time in checking your posts , as you can see the feedback you get depends on it.
FilledVoid is offline   Reply With Quote
Old 01-06-2010, 07:07 PM   #9 (permalink)
in west bengal in bengali language this kind of language mistake is actually taken to be a subtle sense of humor and i have learnt it from the novels of Rabindranath Tagore.
what i intend to mean is that i am serious about RAM just as SAM is serious in that game.
so lyrics goes like that SERIOUS SAM, but here it is Serious (about)RAM.
any how i am sorry.
but no body is answering me to the point i have given.
Old 01-06-2010, 07:28 PM   #10 (permalink)
FilledVoid's Avatar
I can understand . WHich is why I took the time to modify the post in the first place.
any how i am sorry.
No need to apologize.
Refer to Rhits post. basically you want to pair the same frequency RAM modules . I cant give you Corsairs Modules Model numbers thats way beyond my sub par knowledge of the same. So Id wait for folks to chip in.
Old 01-06-2010, 07:33 PM   #11 (permalink)
rkneo11's Avatar
If both your RAM modules are of equal frequency and capacity refer the manual and install in the same coloured DIMMs so that it acts in a dual channel way...
A day without laughter is a day wasted.-Charlie Chaplin.
rkneo11 is offline   Reply With Quote
Old 01-06-2010, 07:59 PM   #12 (permalink)
Tell me onething, by using cpu-z i can get the frequency of my installed RAM. But how can i know the frequency of the RAM which i am going to buy? specially if the RAMs are of two separate companies. For that i need to depend fully on the specifications given in the sites of the respective company.
that is why i am asking for the model no from the xperts of this forum.
Old 01-06-2010, 09:05 PM   #13 (permalink)
Super Moderator
asingh's Avatar
Hi all,
Questions
Answers:
Ram:
Your system supports RAM to a maximum speed of 1600 Mhz. You currently have this ram. So any RAM with speed <= 1600 can be paired to this DIMM, so YES, you can attach the Corsair 1600Mhz sticks. But they will down clock to the slower ram which is your currently installed Transcend operating at 1333Mhz. And this way if you have 3x sticks you will not get Dual channel mode. It will move to asymmetric -- quite a waste. Ideally if you can source 2x2GB Corsairs, then sell of the Transcend.
How to identify RAM:
See the image below. It has the model number (XMS2), Density (1024MB), Speed (800Mhz), Timings (4-4-4-12). So this way you can tell the details.
Which Ram to get:
Decide first what I recommended in the first paragraph, will tell you the exact model number. Tell the budget too. Also company specification against the model number are always correct.
Old 01-06-2010, 09:39 PM   #14 (permalink)
Democracy is a myth
rhitwick's Avatar
Cool Re: Question about upgrading RAM .
Man!!!
U had a problem and u needed its answer.
Why write a poem for it (then including PUN, read Shibram?)
From next time, please be straight forward.
(b/w I'm a bengali too)
Old 02-06-2010, 09:42 AM   #15 (permalink)
Fullbring
Zangetsu's Avatar
any how i am sorry.
so..this type of lyrics u can post in joke section....
Old 02-06-2010, 11:17 AM   #16 (permalink)
Ram:
thanks. so either i have to go for
1)transcend 1333mhz(existing) & corsair 1333mhz
or
corsair 1600 & corsair 1600 mhz
not able to see any image. however i am giving the cpu-z pic of my RAM.
Which Ram to get:
budget still not decided.
now suggest me a 1333 mhz corsair model which can be paired with transcend stuff.with price.
also tell me corsair 1600 mhz 2x2gb (keeping pace with my proccy & mobo.) in case i sell off transcend.
looking at the price you will give i need to accumulate the fund.
Old 02-06-2010, 11:22 AM   #17 (permalink)
Man!!!
i have read whole lot of lit. in my past 45 years.
i do apologise for applying things in wrong place.
Old 02-06-2010, 11:41 AM   #18 (permalink)
FilledVoid's Avatar
Folks, Please drop the issue . Its just an innocent post which already has been edited. I'm sure the Thread Starter understands. And Avi Asigh seems to have given you a very good explanation
Old 02-06-2010, 12:43 PM   #19 (permalink)
yes . i am impressed. waiting for more reply.
Old 02-06-2010, 01:13 PM   #20 (permalink)
Super Moderator
asingh's Avatar
Can you not just sell the Transcend and pick up a 4 GB (2x2GB) Corsair kit. It will be difficult to match those timings. I am always a stickler for "ram should be same company/model/density/speed/timings"...?
Old 02-06-2010, 02:52 PM   #21 (permalink)
yes i also think so.
instead of selling i will keep my it as a TEST RAM.
and what is the price of CORSAIR 4GB? MODEL NO.?
in corsair site i found two types of ram given for amd phenomII class processors AND for my mobo model. so i get confused.
Old 02-06-2010, 04:53 PM   #22 (permalink)
Super Moderator
asingh's Avatar
Corsair TW3X4G-1333C9 4GB DDR3(2x2GB) Kit @ 9-9-9-24 @ 1333Mhz
RS: 7245.00
Old 02-06-2010, 07:04 PM   #23 (permalink)
RS: 7245.00
THANKS.
and what about 1600 mhz?
Old 02-06-2010, 07:36 PM   #24 (permalink)
Cool Buddy's Avatar
Can't the corsair 2x2GB kit be fitted in dual channel and the transcend remain where it is? I mean, 2 corsair's in the red slots and a transcend in the black slot? of course the whole 6 GB will have to be 1333 Mhz, but it will work right?
Old 02-06-2010, 09:46 PM   #25 (permalink)
Super Moderator
asingh's Avatar
No, he will loose the dual channel if he does the above. The memory controller cannot see the whole bunch of DIMMs as 'one' if there are three. Its either 2 or 4.
Corsair CMX4GX3M2A1600C9
Model : CMX4GX3M2A1600C9
Speed : PC3-12800
Memory : 4GB Kit
Latency : 9-9-9-24
Package : 240pin DIMM
@ 7688
Old 03-06-2010, 05:17 AM   #26 (permalink)
Cool Buddy's Avatar
OK, that clears my doubt, thanks
Old 03-06-2010, 07:12 AM   #27 (permalink)
INS-ANI's Avatar
Since ongoing discussion is about something i need to query.. let me shoot a question as well..
I have a inpiron 1420 and am using 667MHz DDR2 samsung RAM (2GB).. i am running it on 965 chipset plus C2D T5450.
Now all i want to know is:
1) what other Operating freq available in DDR2? 800 MHz is what i am aware of.. any faster ?
2) if i use a 667MHz Ram and a 800Mhz Ram, will it be an issue?
3) will my system support DDR3?
Under dogs are still dogs...till they don't bite! 8-)
My GF is a bomb.. she wears a bomb vest and threatens to blow her up now and then :CiobarAbt2Cry:
http://twitter.com/INS_animesh
INS-ANI is offline   Reply With Quote
Old 03-06-2010, 10:47 AM   #28 (permalink)
Speed : PC3-12800
Memory : 4GB Kit
Latency : 9-9-9-24
@ 7688
THANKS.
well, i understand memory, package,model. but regarding speed i know it in Mhz then what is that PC3-12800 mean? and often i have seen this type of number given in the specification of RAM.
and
Latency is what?
Old 03-06-2010, 11:10 AM   #29 (permalink)
Cool Buddy's Avatar
Yes, 1066 Mhz is available, though not sure if 1066 Mhz laptop RAM is available or not. But your motherboard might not support it.
Yes, your system wil not be stable, you can only use separate modules of same frequency
no
---------- Post added at 11:10 AM ---------- Previous post was at 10:58 AM ----------
in PC3-12800, the 3 corresponds to DDR3. I don't know exacltly what the larger number denotes, but if you devide it by 8, you will get the RAM frequency. For example, PC3-12800 is 1600 Mhz DDR3 RAM.
Latency is a very complex prperty (at least for me). The only thing you really need to know is that the lower the better. For more information about latency you can read http://en.wikipedia.org/wiki/SDRAM_latency
Old 03-06-2010, 11:18 AM   #30 (permalink)
INS-ANI's Avatar
how can i verify that?
Approx Kingston/Corsair RAM Price mehrotra.akash Hardware Q&A 0 25-04-2010 02:35 PM
RAM Dilemma ShadowKnight Hardware Q&A 5 15-04-2010 10:07 AM
Upgrading RAM Aztec_in Hardware Q&A 7 05-09-2006 02:39 AM
upgrading rd ram help thadhanihemant QnA (read only) 3 16-07-2006 05:05 PM
