Old 01-06-2010, 03:54 PM   #1 (permalink)
Default which is the best gaming laptop within 60k (if necessary expandable upto 80k) ???
i wanted to know which would be the best gaming laptop available within 60k rs with a good video card(ati radeon hd 5970 ) , minimum of 4GB ram , 500 GB hard disk and a good battery life..
i would prefer a minimum of 15" screen.
thank you..
email goji_stan@yahoo.co.in
Stanzin is offline   Reply With Quote
Old 01-06-2010, 06:05 PM   #2 (permalink)
Linoob
celldweller1591's Avatar
Default Re: which is the best gaming laptop within 60k (if necessary expandable upto 80k) ???
you can go for HP DV6 series or Dell studio XPS 16/17 or Sony Vaio VPS-EB1S1E/BJ. I think all of them vary b/w 55-65k
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline   Reply With Quote
Old 01-06-2010, 07:10 PM   #3 (permalink)
Smile Re: which is the best gaming laptop within 60k (if necessary expandable upto 80k) ???
Well the budget is definitely in the gaming span. If you are going for the lower limit of the budget then for the required config you can buy HP dv6. It comes with a 1GB graphics card, but the design is rookie and the laptop tends to heat up like hell. If you are a game enthusiast then get a Alienware M11x . That will meet your requirements and it has been rated as the best smallest gaming laptop. It's bulky but heck gamers dont move around much. In India only XPS 16 and 13 are available. You will get XPS 16 at 72000, with 500GB hd, 1 GB graphics card, i7 processor. That is much more portable than alienware. It gives a classy look. Chuck XPS 13 out. Its not in the gaming race. Go between M11x or XPS 16. Thats my choice.
V@run_Zx is offline   Reply With Quote
How to play movies/project screen from laptop to TV ??? sohin Hardware Q&A 0 14-02-2010 11:44 PM
Budget laptop suggestion needed (upto 25K) ashu888ashu888 Hardware Q&A 2 14-02-2010 12:54 AM
Need Laptop Upto 55 - 60K abhipal Hardware Q&A 5 21-08-2009 12:18 AM
Acer Aspire 4720 Z Laptop Review FilledVoid Reviews 8 11-01-2008 05:06 PM
help me to buy laptop....upto 60k thinktwice Hardware Q&A 2 09-08-2006 12:16 PM
