Re: Comptuer for animation
1. What is your MAX budget? -- Upto 90,000 maybe 1 Lakh
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why? -- Yes
3. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that) -- Animation, Rendering
4. Planning to overclock? -- No
5. Which OS are you planning to use? -- Ubuntu
6. How much hard drive space is needed? -- 500 Gb - 1Tb
7. What resolution will the screen run at? -- 1920 X 1080
8. How would you rate your hardware knowledge from the count of 1-10? (1 being the lowest, 5 being you are somewhat in sync with the current performers and 10 being the highest) -- 7
9. Have you ever built a desktop before or will this be done by an assembler? -- No, it will be done by assembler
10. When are you planning to buy the system? -- may by october or november 2010
11. Are you one of the types looking out for "future proof" configurations? -- Yes
12. Are there going to be any components that you don't want to include in this new rig? If yes, do mention. -- No
13. Which city do you live in and are you open to buying from shops from other city/states? -- Delhi, Delhi
14. Mention any other points if deemed necessary --
I want to use the graphics card mentioned above in my post. So please don't recommend ATI firegl cards.
Also I will be using Maya, Blender, Cinema 4d and Vue 8. I am a professional.
