Old 01-06-2010, 07:10 AM   #1 (permalink)
Anish's Avatar
Default Display problem
hi,
i have a lenovo laptop with 14.1" tft widescreen. The problem is when i play the digit cd or any games such as rise of nations, the screen shrinks like in the image below
http://i50.tinypic.com/10sdoah.jpg
I installed all display drivers.. games such as claw v1.2 runs well in wide screen resolution what is the problem should i change any settings
TIA
The secret ingredient is nothing
Anish is offline   Reply With Quote
Old 01-06-2010, 07:50 AM   #2 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Re: Display problem
its coz u have a widescreen with a ratio 16:10 and these games/apps or even some videos have ratio of 4:3 (so that anyone having a normal screen can dosent have a prob).
so chill! there is nothin wrong
---------- Post added at 07:49 AM ---------- Previous post was at 07:45 AM ----------
here this will help u understand better : http://forum.videohelp.com/images/gu.../4x3source.jpg
cheers
---------- Post added at 07:50 AM ---------- Previous post was at 07:49 AM ----------
only games having a option of widescreen can be played in widescreen! rest will get black area on de sides!
ankushkool is offline   Reply With Quote
Old 02-06-2010, 05:49 AM   #3 (permalink)
Anish's Avatar
well i got it thank you dude
system boots but no display vickybat Hardware Q&A 2 19-03-2010 11:48 AM
Wierd LCD problem Psychosocial Hardware Q&A 2 10-03-2010 02:20 AM
HP Laptop. Display Brightness Problem. aminsagar123 Software Q&A 3 26-06-2008 02:55 AM
Clusty, Firefox Bug/Plage Display Problem... ShekharPalash Internet & WWW 5 25-10-2004 11:54 AM
