Results 1 to 9 of 9
  1. #1
    Mar 2009
    India
    Default Odering PC in next 2 days, need suggestions...
    I am ordering a new PC basically for 3d modelling....a lil gaming, and HD movies.....
    I am buying
    core i5 750 with some intel original p55 board-16800
    samsung 22" ~ 9400
    some frontech cabinet and 650 watt smps ~ 2500
    4 gibs ddr3 1333mhz ram ~ 5500
    dvd drive ~ 1100
    speaker creative 2.1 ~ 1350
    wireless keyboard mouse, logitech ~ 1500
    ups 700va~ 2500
    HDD 500gb~2500
    Gpu?????~5770??or5670??
    Plz suggest which GPU should opt for? and is this config AOK??
  2. #2
    sam
    sam is online now
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    Default Re: Odering PC in next 2 days, need suggestions...
    Quote Originally Posted by ani1751 View Post
    I am buying
    samsung 22" ~ 9400
    dvd drive ~ 1100
    ups 700va~ 2500
    HDD 500gb~2500
    why don't you consider the new AMD 6core? its cheaper & as your primary use 3D modelling, will be better buy. also opt for some other motherboard if you fixed on i5.
    get a good cabby + not any 650W PSU. get FSP Saga II 400W (order online if not available). or get Corsair VX450W (if you choose HD5770).
    get APC 650VA @ 2.8k. good buy at that price.
    500Gb HDD will cost you 2k-2.2k
    for HD gaming, get HD5770. if you do only casual gaming, HD5670 should suffice.
  3. #3
    Mar 2009
    India
    @sam.shab i was waiting for more than 2 months to get core i5 in my city, now finally i am getting it, if i will try for amd 6 cores, it will be hazardous for me.....
    and i am not able to get a good cabby and psu in my city(gwalior) and moreover my budget will be ruined with a good cabby and psu, is it that much necessory??
    Will it make a lot difference with a diff with 3-4k in 5770 and 5670???
  4. #4
    Alpha Geek ajai5777's Avatar
    Nov 2008
    An AMD X6 will be good for processing works and casual gaming.Also its very much future proof.
    It smells danger
    You can cut down in cabby but not in PSU.Its the base of a rig or else you will end up with a blown PC.
    you can adjust with zebronics bijli @.9k
    but for PSU it should be atleast FSP Saga II 400 or Gigabyte 460W @ 2-2.2k range.But for a 5770, it should be corsair vx 450W @ 3.5k.
    Good PSU is a must for the rig.
    Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|HEC Raptor 500W|APC 650VA
  5. #5
    Super Moderator asingh's Avatar
    May 2008
    New Delhi
    If you go by this thought process, then one day your system will be ruined. Please get a decent/good PSU. It is the heart of your system, which feeds the life blood. Rest is your choice.
  6. #6
    sam
    sam is online now
    Jan 2010
    Guwahati
    about first question, ajai already gave the answer.
    about second part asigh already gave an excellent reply. still just know, a good PC + a bad PSU (not necessarily cheap) = you purchasing a timebomb.
  7. #7
    Wise Old Owl Cool Buddy's Avatar
    Mar 2006
    Milky way
    My suggestion, get a good PSU to support your i5 & 5770 or 5670 whichever
  8. #8
    In The Zone evewin89's Avatar
    Sep 2007
    corsair_cx400
    FSP-SAGAII-400
    FSP-SAGAII-500
    my budget is max Rs-2800 for the psu,
    out of the three i personally like the looks of corsair_cx400 but its little bit expensive as with the same amount i can get FSP-SAGAII-500 but the look of
    corsair_cx400 is driving me crazy...so guys wat u suggest.
    i'll be buying the following config.
    CPU
    AMD Athlon II X4 630
    MOBO
    Biostar TA785G3 HD
    HDD
    WD CAVIAR BLUE 1TB
    GFX CARD
    SAPPHIRE HD 5670 512MB GDDR5
    Evil Lives 4ever......
  9. #9
    teh tech saviour! saurabh_1e's Avatar
    Oct 2008
    de_dust2
    corsair will suffice you that 's no doubt
    ........you should go with corsair that's what my choice would be
    AMD Phenom x6 1055T @3.50ghz || MSI R6850 @925Mhz OC/PE || 2X2 GB RIPJAWS 1333CL8 || CM 460W REAL POWER ||Asus M5A97 EVO || Lancool PC-K62 || Sennheiser HD201+Fiio E5 || Logitech G400+Razer Golathius || Epson TX121 with CISS || Arch Linux ||
  1. Getting a new mobile within few days
    By soumo27 in forum Buying Advice
    Last Post: 01-05-2012, 02:44 AM
  2. Need To Buy PSP in 2 Days Help!!!
    By Ayuclack in forum Consumer electronics and everything else
    Last Post: 01-02-2012, 12:39 AM
  3. 30 Days With A Macbook Pro
    By blackpearl in forum Chit-Chat
    Last Post: 05-08-2007, 08:51 PM
  4. What after 7 Days...
    By ShekharPalash in forum QnA (read only)
    Last Post: 21-10-2004, 08:01 PM
