Re: How to install wireless router?
whats the router model..?
anyway..
installation will be easy.. follow u r router manual that came with the router box.
usually they will provide a installation CD use that..
and set WPA2 encryption in router settings..
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
