Old 29-05-2010, 02:33 PM   #1 (permalink)
Default Confused!help
i am confused of different version of hd4670 512mb(sapphire). planning to buy one. but confused among:
SAPPHIRE HD 4670 512MB GDDR3 PCI-E (New Edition)
SAPPHIRE HD 4670 512MB GDDR3(HDMI On-board)
SAPPHIRE Ultimate HD 4670 512MB GDDR3 PCI-E
SAPPHIRE HD 4670 512MB GDDR4 PCI-E (HDMI On-board)
SAPPHIRE HD 4650 512MB GDDR3 PCI-E
please explain the difference.
will these be available in kolkata?
also the price.
g160689 is offline
Old 29-05-2010, 02:51 PM   #2 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Default Re: Confused!help
Saphire HD 4670 GDDR3 HDMI @ 4.4k
best would be Sapphire HD 5670 GDDR5 DX11 @5.4k
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline
Old 29-05-2010, 03:13 PM   #3 (permalink)
@ajai5777: thanx for ur suggestion. I found some post stating that hd 4670 512mb:2.9k.
which version is that?
g160689 is offline
Old 29-05-2010, 03:51 PM   #4 (permalink)
i2 heard such a rumor. but maybe it was just a typo. Metal Head Gautam quoted HD4670 available for that price. but street price is 4-4.5k. you may try get your hands on HD5570 if found for 4.5k. performance wise, both are same. just price matters
Sam is online now
Old 29-05-2010, 05:10 PM   #5 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
That must be a mistake its HD 4650 512MB DDR2 @2.9k
---------- Post added at 05:04 PM ---------- Previous post was at 05:01 PM ----------
No 4670 with DDR2 ram and Nothing under 4k
---------- Post added at 05:10 PM ---------- Previous post was at 05:04 PM ----------
HD 5570 is faster than HD 4670.Also it has got DX11
Then go for HD 5570 512MB DDR3 @ 4.4k
ajai5777 is offline
Old 29-05-2010, 05:27 PM   #6 (permalink)
Cool Buddy's Avatar
I don't think GDDR4 exists, go for a 512MB or 1GB GDDR3 card. should cost around 4-4.3k in Kolkata. available at Saboo, Bengal Chemical building on G. C. Avenue.
Cool Buddy is offline
Old 30-05-2010, 08:55 AM   #7 (permalink)
i found gddr4 version in the sapphire website itself. Have a look:
http://www.sapphiretech.com/presenta...000101&pid=204
g160689 is offline
Old 30-05-2010, 11:26 AM   #8 (permalink)
Cool Buddy's Avatar
I'd never heard of any GDDR4 card, so I thought it had been skipped in favour of GDDR5. If it does, then it must be better than GDDR3.
Old 30-05-2010, 01:53 PM   #9 (permalink)
GDDR4 was used only in HD3870 & 3870X2. maybe Sapphire got some old stock of GDDR4 left so using it here.
@OP, each manufacturers make many variants of same card & getting each one available is not easy. even if Sapphire card freely available in India, many cards from Sapphire itself are not. so pre-planning may give you a little sad time. do a market survey before jumping on any particular card.
Sam is online now
Old 30-05-2010, 05:30 PM   #10 (permalink)
Cool Buddy's Avatar
yes, when I was looking for the same card, Many shops said they did not have the card. many of them didn't have GT 220 DDR3 either. saboo offered the lowest price on 4670 1GB DDR3, but that was Palit or XFX card, don't remember very well.
Eventually I didn't buy the card cuz I figured I would have to change the PSU too for which I did not ahve money & did not want to go for anything lower than 4670.
Old 30-05-2010, 10:45 PM   #11 (permalink)
HD4670 can run on desi PSU of 400W-500W.
Sam is online now
Old 30-05-2010, 10:51 PM   #12 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
ya even I had run my HD 5670 in zebronics 450W Sata plus for a month with out any issue.
ajai5777 is offline
Old 30-05-2010, 10:57 PM   #13 (permalink)
yes, it'll run without any problem.
Sam is online now
Old 31-05-2010, 05:26 AM   #14 (permalink)
Cool Buddy's Avatar
It was this forum itself which made me feel that I should change my PSU, it's a frontech 450W. I didn't want to take any risk as my computer is kept in such a way that it is always 2-3 degrees hotter than normal & i can find no way to move it.
Old 31-05-2010, 01:13 PM   #15 (permalink)
that way u took right step. however HD4670 will run on a 450W desi PSU provided you got some entrylevel stuffs.
Sam is online now
