Originally Posted by desiibond
How is data/usb cable?
Have you tried connecting it to any other pc?
See If you can download wd diagnostic tools and test.
Cable is fine anna,
Shows the partition, but not able to access it, Wd diagnostics are built in the HDD casing ROM but it shows no disk to diagnose.
Can't try it in another pc till tomorrow.
Tried to recover data with EASUS data recovery, it shows all my files though it takes ages to scan fully.
So I feel somehow my MFT or partition table is corrupted and all my files are intact.
Is there any way to repair MFT anna??
---------- Post added at 11:39 PM ---------- Previous post was at 11:36 PM ----------
Originally Posted by sujoyp
If u have no way left ...install R-studio data recovery software and try...it recovered 80gb of my friends data after crash
Easeus is showing my data, but right now I don't have 300GB free space to recover the data
And as I said above, I want to try and repair Master File table first before going through the long recovery process
---------- Post added at 11:41 PM ---------- Previous post was at 11:39 PM ----------
tried
test disk
but not able to figure out what to do with it
---------- Post added 29-05-2010 at 12:57 AM ---------- Previous post was 28-05-2010 at 11:41 PM ----------
Ok not able to fix MFT by any means
Atleast I'm relieved that my data is intact. Tested by recovering a few big files.
So I have to beg/borrow a 320GB hdd from friends to copy my data
