Old 28-05-2010, 06:46 PM   #1 (permalink)
The Game.
prateekdwivedi1's Avatar
Default Advice needed over buying a laptop
Hi
i am a 12th pass student and am deciding where to go for higher studies
i have opted for cs in vit and thus am looking for a suitable laptop for me
looks do not matter but the thing has to be a good performer
it does not need to be a graphic monster but graphic power should be enough to run the newer games at full low settings
and yes a large hard disk would be much appreciated
thank you
prateekdwivedi1 is offline
Old 28-05-2010, 07:02 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: Advice needed over buying a laptop
How can we suggest anything if you don't mention your budget??
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 28-05-2010, 07:52 PM   #3 (permalink)
laborare est orare
Cilus's Avatar
I think it is the time for playing games for you, apart for your higher study thing.
If gaming is the scene, then go for ACER 5740g, champion performer in price. Its price is within 43k.
Basic configuration is like
Core i5 420M 2.23 GHz (turbo Boost @ 2.53 Ghz)
4 GB DDR3 1066 MHz Ram
500 GB SATA II 5400 rpm HDD
15.6" Acer Crystal Display with Max Res 1366X768
4 USB
Card Reader, Dolby Digital Sound output
2.8 Kg Weight.
Batter: 3 Hrs for normal use
You can check performance review in all the sites and every where it excels.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now
Old 29-05-2010, 05:29 AM   #4 (permalink)
Anish's Avatar
Choises in order:
1. Dell studio 14
2. lenovo ideapad z series
3. sony viao
These are the best brands offering good support and service
The secret ingredient is nothing
Anish is offline
Old 29-05-2010, 07:57 AM   #5 (permalink)
Its Best only if its open
ankushkool's Avatar
+1 for ACER 5740g... go for minimum 15inch screen. dell studio 15 is also a good option!
---------- Post added at 07:57 AM ---------- Previous post was at 07:56 AM ----------
and for HDD u can get a external one later
ankushkool is offline
Old 29-05-2010, 10:48 PM   #6 (permalink)
The Game.
4 USB
2.8 Kg Weight.
thanks a lot buddy
that really helps
Need advice on buying iphone from us? raja2281 Buying Advice 3 06-05-2010 01:16 PM
Needed suggestion for buying 1.5. ton Air conditioner at <17k.. Sathish Chit-Chat 1 15-04-2010 09:20 PM
Urgent help needed for buying laptop chirayu garg Hardware Q&A 2 30-09-2009 07:33 PM
Buying AMD 64 bit. Advice needed rajendra99 CPU / Motherboards 15 29-08-2004 09:53 AM
