Old 28-05-2010, 03:29 PM   #1 (permalink)
Unhappy Errors during burning a CD/DVD
Hi Guys,
The problem with my computer is that whenever i try to burn (using nero 8) any dvd of 4.7GB of any brand(mostly i use sony or moserbaer) an error message gets on the display saying "Burn process failed" and "failed to complete Disk-at-once" ; but whenever i do it on a 8.5GB blank dvd it burns perfectly. can anybody tell me what could be the problem????? plz..........
My System Configuration is:
intel core 2 duo E7400 2.80Ghz processor
AsRock 945 motherboard
2GB RAM
160 GB HDD
Windows 7 Home Premium
Nvidia 8400 GS graphics card
ATAPI iHAS124 Y ATA DVD RW drive
b_chax06 is offline
Old 29-05-2010, 12:36 PM   #2 (permalink)
Default Re: Errors during burning a CD/DVD
This can happen bcoz of 2 ways-
1)You have a driver problem (This is the least probable cause)
2)The DRIvE LENS HAS SOME DUST(tHE COMMON ONE) --If ur drive is under warranty' send it 2 company.If not go for a drive cleaner kit from a comp store.
If this doesn't work and your drive is too old, go for a replacement.
kunal grover is offline
Old 29-05-2010, 12:45 PM   #3 (permalink)
CA50's Avatar
try different medium, this may be a medium compatibility issue
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 29-05-2010, 05:33 PM   #4 (permalink)
Cool Buddy's Avatar
change the write mode from disk at once to trakc at once and choose UDP 1.5 as disk format. Clean your Drive's lens using a lens cleaner (philips lens cleaner @ 150). might help. Try a different burning software (cyberlink power2go or infrarecorder from portableapps.com)
Cool Buddy is offline
Old 29-05-2010, 09:43 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Choose the lowest burn speed and try.
asingh is online now
15 Free CD/DVD burning alternatives to Nero blackpearl Reviews 22 03-12-2007 04:40 PM
Difference between burning CD/DVD as MP3 Vs burning as DATA CD/DVD in Nero ajayritik Software Q&A 1 06-09-2007 07:33 PM
World’s Largest Windows Error Message iMav Random News 46 01-04-2007 07:08 PM
DVD writer not working properly blacklisted Hardware Q&A 12 31-07-2006 10:40 AM
Errors on Burning CDs anoopingenius Hardware Q&A 4 01-05-2006 10:54 AM
