Old 27-05-2010, 09:00 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Cool Core i3 vs athlon ii x4 upgrade
Hey Guys,
Planning to upgrade my aging Athlon64 based sys... RIP baby!
Will use the rig for browsing, dev work (will run an app / web server / eclipse) and casual gaming. Thinking between Core i3 vs Athlon ii X4.
Points to ponder:
1. i3 consumes lesser power, runs cooler
2. i3 much better overclocker (wil easily go to 3.4GHz on stock HS!!)
3. Most sw products in the next few years, though multithreaded, would see only small % diff due to 4 cores (vs 2). Think i3 offers a decent compromise, 2 physical cores, plus HT for a small boost for apps supporting higher num of threads.
Courtesy: Excellent Review @ http://techreport.com/articles.x/18448
Though a long time AMD fan, these points are making me lean towards i3. Do provide solids args in support/favor of a i3 rig.
Also suggest a suitable sys (budget around 15.. willing to stretch to 20k if u can convince me its worth) for [cabinet + smps + mobo + proc + gfx card(< 5k) + 4gb ram + 500gb hdd].
Thanks Guys!
hurricane25 is offline   Reply With Quote
Old 27-05-2010, 09:17 PM   #2 (permalink)
Default Re: Core i3 vs athlon ii x4 upgrade
Originally Posted by hurricane25 View Post
Hey Guys,
Points to ponder:
Also suggest a suitable sys (budget around 15 to 20k) for [cabinet + smps + mobo + proc + gfx card(around 5k) + 4gb ram + 500gb hdd].
Thanks Guys!
20k too less for i3. frankly. i3 530 ---> 5.6k
cheapest HDD, Biostar ---> 4.9k.
total: 10.5k. now 4Gb DDR3 ---> 5.4-5.8k
500Gb HDD ---> 2.2k
Elite 310 + FSP Saga II 400W ---> 3.5k
you already went past 21k without touching graphics card. & with Intel's graphics, gaming will be a distant dream.
with AMD, get these:
Athlon II X3 435: 4k
Biostar TA785G3 HD: 4.1k or Gigabyte 740G based motherboard at 2.6k
4Gb DDR3 Value ram: 5.6k
500Gb HDD: 2.1k
FSP Saga II 400W: 2.1k
Elite 310 or similar: 1.5k
total: 19.4k or 17.9k (considering the giggy).
so game using the onboard HD4200 or stick up a HD4650 @ 3k or less to game at high settings.
Old 28-05-2010, 12:30 AM   #3 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Hey Guys,
Points to ponder:
Thanks Guys!
Athlon II X4 630 is anyday better than i3 530.After all it has got 4 physical cores.So its better for future.Also it can touch 3.4Ghz in Stock.Even I am running it in 3.3Ghz in stock.Most CPU hungry programs have affinity for more cores and we will get the full advantage of 4 cores in those applications like converting ,encoding etc.Only games are not developed for 4 cores (but it will happen soon) anyway I am getting decent performance in games.
In short, Athlon II X4 630 got much more processing capability.Have a look at the CPUmark by the passmark softwares.
CPU Mark
Note the CPU Mark given for both the proccys
Athlon II X4 630 @ 2.8 Ghz = 3364
Intel Core i3 530 @ 2.93 Ghz = 2701
config is
Athlon II X4 630 @ 4.6k
Biostar TA785G3 HD @ 4.1k
Transcend 2GB DDR3 1333 @ 2.6k ( If you severely need 4GB go for it @ 5.2k)
WD caviar Blue 500GB @ 2k
Gigabyte APFC 460W @ 2.2k
Zebronics bijli with out SMPS @ .9k
Saphire HD 4650 512 MB @ 3k
Total 19.4k with 2GB ram. 22k with 4GB ram.
I would suggest you to go for 2GB now and add 2GB later.
If you really need 4GB skip Graphic card now and game in IGP HD 4200.
Its pretty decent.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 28-05-2010, 05:53 AM   #4 (permalink)
Cool Buddy's Avatar
I would suggest going for 2 GB RAM (Single module) now and an HD 4670 @4k with ajai's config. RAM will become cheaper within a year & you would be able to get a 2 GB one for 1.5k 1 year from now (I hope, considering similar falls in DDR2 prices 2 years back). So you can add another module then.
HD 4670 is will need just 1k over 4650 but performance difference will be considerable. You will be able to run games at decent settings.
Old 28-05-2010, 08:29 AM   #5 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
He told he's a casual gamer thats why I suggested 4650.But HD 4670 is a gaming card @4k VFM. He can play most games in quality settings.
Old 28-05-2010, 09:24 PM   #6 (permalink)
Cool Buddy's Avatar
yeah, 4650 is ok for casual gaming, but since 4670 is much better VFM, I suggested it.
Old 30-05-2010, 01:59 PM   #7 (permalink)
Cool Re: Core i3 vs athlon ii x4 upgrade
@ajai5777
The athlon ii x4 config looks gr8, and i think 2 gb ram + HD 4670 seems a gr8 choice.
but i need more convincing as to whether athlon x4 scores over i3 in scenarios other than encoding (which I hardly use). Wouldn't superior architecture of i3 & more L3 cache overscore the athlon II x4? Could u show me some reviews which use app performance rather than synthetic tests like CPUMark??
Also, in most of the reviews, i3 seems to have the edge in gaming and real-time apps. Also, we r going to reach a barrier pretty soon in the threading vs performance gains. Thr is a limit to how much u can parallelize task execution (multi-threading) in app..
Guys,
Though, i3 proc is just 1k above athlon ii x4, y are the lga1156 mobo's so frigging expensive??
Forgot to mention, I am running a 22" sony lcd tv as my primary monitor, so need a decent card which can support games @ 1366 by 768 res. Do confirm if HD 4670 can handle it...
Old 30-05-2010, 02:36 PM   #8 (permalink)
I am the night! I am....
vickybat's Avatar
The i3 530 is a fantastic proccy and can be overclocked to 4ghz in stock. Its a delight for gamers and worth the extra 1k premium over the x4 630. In some games it even beats the x4 965.
Since it supports hyperthreading,4 cores (2 physical & 2 logical would be available) would be available and will take care of multitasking and threaded apps.
Refer this link & make your decision. Still in gaming point of view the i3 wins handsdown & in encoding apps its a close call between itself & the x4 630.
Opt for h55 chipsets as these are cheaper than p55 & h57.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is online now   Reply With Quote
Old 30-05-2010, 02:38 PM   #9 (permalink)
@ajai5777
i3 is basically a dual core. i3 yields real life results in favor of it only once you OC it. without OC, X4 better than i3. moreover i3 can't be OC on stock HSF. X4 can. see ajai's signature.
Guys,
in 1 line cause "Apple expensive than Orange".
all depends on which games you play. Crysis, yes, but low setting. everything set to low.
Old 30-05-2010, 02:46 PM   #10 (permalink)
vickybat's Avatar
Guys at Anandtech have overcloced the i3 530 to 4ghz using stock HSF WITHOUT any stability issues.Check the above link i had given.
Old 30-05-2010, 05:40 PM   #11 (permalink)
Cool Buddy's Avatar
It's better not to over clock that much on stock HSF. OC for testing purpose is different, in normal conditions it will be running for hours at those speeds. so stick to a moderate 10-15% OC. it also depends on the motherboard. Otherwise get a better CPU cooler (fan) also get a cabinet with atleast one inflow & one outflow fan & a very good PSU if you plan to OC.
One thing more, if people at anandtech blow up the CPU, it won't be a big problem for them, but at home...
Old 30-05-2010, 05:48 PM   #12 (permalink)
vickybat's Avatar
Ya its not advisable to oc that much using stock hsf but its a proof that the i3 can be o'ced as much as x4 630 maybe beyond and give better results.
Old 30-05-2010, 08:29 PM   #13 (permalink)
rkneo11's Avatar
i3 uses less power but Athlon is lighter on the pocket...
Considering you'll be changing it in 2 years go for the Athlon...
A day without laughter is a day wasted.-Charlie Chaplin.
rkneo11 is offline   Reply With Quote
Old 31-05-2010, 08:20 AM   #14 (permalink)
the i3 performs far better in single threaded apps, Athlon X4 is better when its a multi threaded app. The AMD IGP is generally better, so thats another pro.
i3 530 can be easily OCed to 3.6GHz on stock HSF with a small voltage bump.
Win hardware worth 11k!!
rajan1311 is offline   Reply With Quote
Old 08-06-2010, 10:26 AM   #15 (permalink)
AMD has upgraded their athlon ii range to C3 revision silicon. Check the below article:
http://www.cpu-world.com/news_2010/2..._pictures.html
this translates to less power consumption/heating... so more overclocking
Guys, have any of you tried the C3 version of athlon ii x4? do rate its overclocking potential...
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/127407-core-i3-vs-athlon-ii-x4-upgrade.html
Thread amd athlon vs i3 300m vs t4500 | Computer Forums | BoardReader This thread Refback 19-10-2010 03:44 AM
Core i3 myth or reality??? Please help sanderz178 Hardware Q&A 5 17-05-2010 12:29 PM
advise needed for new sysem upgrade... DANTE_SSS Hardware Q&A 2 18-04-2010 09:01 PM
PC upgrade under 15k vinyasmusic Chit-Chat 4 02-02-2010 10:03 PM
diff between Intel dual core,Core 2 , Duo?? NagpurDaMunda CPU / Motherboards 26 21-07-2007 06:37 AM
Athlon Core parimal Hardware Q&A 5 25-05-2007 08:45 PM
