Old 26-05-2010, 01:38 PM   #1 (permalink)
Cool Suggest a rig for 30k
1. What is your MAX budget?
Budget 30k(including monitor and ups).
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
No.I better go with good brand name.
3. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
Its for home purpose. I use it for browsing , videos , games and some programming stuff.
4. Planning to overclock?
NO.
Win XP or Win7.
1TB
7. What resolution will the screen run at?
1280 x 1024
5
NO.
With in a week or two.
Yes.
Dvd Writer.
Hyderabad.
pboy is offline
Old 26-05-2010, 02:01 PM   #2 (permalink)
bORn To RIse....
rahul.007's Avatar
Default Re: Suggest a rig for 30k
Athlon II X4 630 2.8GHz @ 4.7k
Biostar TA890GXE @ 6.6k
kingston 2*2GB DDR3 1333MHz C9 @ 5.3k
Seagate Barracuda 7200.12 1TB @ 4.2k
FSP Saga II 400 Watts @ 2.3k
Cooler Master Elite 310 @ 1.5k
BenQ 22" G2220 FULL HD LCD Monitor @ 7.5k
logitech keyboard + mouse @ 0.6k
apc 550va @ 2k
total-34k....
biostar 890 gxe is enough for casual gaming at that resolution.... i could have suggested 20" monitor but fr just 600-700 bucks more you are getting a superb 22" monitor....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline
Old 26-05-2010, 02:04 PM   #3 (permalink)
forget about question & answer and get this:
Processor: Athlon II X3 435 2.9GHz @ 4k (try unlock the 4th core)
Motherboard: Biostar TA785G3 HD @ 4.3k (will be cheaper. say 4k)
Ram: Kingston 2GB DDR3 1333MHz @ 2.9k (will be cheaper)
Hard Disk: Western Digital Caviar Green 1TB @ 3.5k (green but still not too slow)
Graphics Card: Sapphire HD5670 512MB @ 5.3k
Optical Drives: LG GH22NS50 22X @ 1.1k
PSU: FSP Saga II 400 Watts @ 2.3k (will be less costly locally)
Cabinet: Cooler Master Elite 310 @ 1.5k
Monitor: BenQ G2020HD 20" LCD Monitor @ 6.5k (maybe bit more costly)
Keyboard Mouse: Logitech Internet Desktop @ 0.6k
Speaker: Altec Lansing BXR1121 @ 1.2k
UPS: APC 550va @ 1.8k
Total: total 35k. if u can't give out the extra 5k, drop the graphics card & game @ 1024X768 or similar resolution. add card later along with another DDR3 stick.
Sam is online now
Old 26-05-2010, 03:24 PM   #4 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Mix the above rigs to get
Biostar TA785G3 HD @ 4k
Transcend 2GB DDR3 1333MHz @ 2.6k (add 2GB later)
Western Digital Caviar Blue 1TB @ 4k
Creative SBS A300 2.1 @ 1.3k
APC 550va @ 1.8k
Total 30k
He hasnt mentioned GPU in his requirements.So go with IGP now.If you want GPU add 5.3k to get HD 5670 512MB
@ rahul
890GXE is too much for home PC used for browsing,movies and casual gaming.
So as 4GB ram.
@Sam
He doesnt need a DVD RW.Also its better to go for X4.I personally prefer creative.My 5 year old Inpire 4400 4.1 rocked and still rocking.My current Inspire T6100 rocks big time.My friend has A 300 and its worth for the money.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline
Old 26-05-2010, 03:43 PM   #5 (permalink)
APC 550va @ 1.8k
Total 30k
@ rahul
So as 4GB ram.
@Sam
22" monitor & IGP? will it be a good choice?
well i just gave him a simple speaker. speaker preference is personal. i like the Creative A300.
Sam is online now
Old 26-05-2010, 04:23 PM   #6 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
I have that board.Its name itself is HD.It can support 1920 X 1080.Even blu ray movies can be played.For gaming he need to play at lower resolutions.
Otherwise an HD 5670 512MB @ 5.3k.
---------- Post added at 04:23 PM ---------- Previous post was at 04:16 PM ----------
I dont know why people want to play games in native resolution only.Only aspect ratio is important for me.I can game in any lower resolution.I was playing SHIFT in 853 X 480 when I had 9500GT
ajai5777 is offline
Old 26-05-2010, 04:52 PM   #7 (permalink)
yes, it can. problem only starts when trying games. running games at 1024X768 on a 20" looks ugly. 22", it'll worth more invest in a HD4670. yes he'll loose DX11. but will a bit of extra muscle.
Sam is online now
Old 26-05-2010, 06:11 PM   #8 (permalink)
Thanks for the suggestions.......I also want to know the equivalent configuration for intel processor.I am in dilemma whether to go for intel or AMD processor.Which is best for home pc.
pboy is offline
Old 26-05-2010, 06:16 PM   #9 (permalink)
bORn To RIse....
rahul.007's Avatar
go with amd eyes closed.... athlon II*4 630 is a great vfm proccy which can easily thrash the more costly i5 660.... and no1 here is going to suggest you a c2xx proccy.... they are on their way out....
Old 26-05-2010, 06:53 PM   #10 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Forget Intel dude..!! Go for AMD. All the avobe config's are gr8.
+1 to Everyone
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 26-05-2010, 07:01 PM   #11 (permalink)
bORn To RIse....
rahul.007's Avatar
go with amd!!!!
PUM--------PUM-PUM-PUM-PUM
Old 26-05-2010, 07:15 PM   #12 (permalink)
pulsar_swift's Avatar
30K and intel ? Forget about quadcore then.
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline
Old 26-05-2010, 07:23 PM   #13 (permalink)
for same performance: Core2Quad or Core2Extreme. X48 (DDR3 based). and a graphics card cause game + Intel graphics = a killer spoiler.
for same price: forget it.
Sam is online now
Old 26-05-2010, 07:42 PM   #14 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Now people may think that AMD is paying us for promoting them.
ajai5777 is offline
Old 26-05-2010, 09:34 PM   #15 (permalink)
bORn To RIse....
rahul.007's Avatar
kaash aisa hota....
waise bhee we all always try to give the best possible solutions at minimum budget.... and AMD RULES LOWER BUDGET SEGAMENT....
Suggest a PSU... Swift Hardware Q&A 43 22-06-2010 10:27 PM
suggest a mouse within rs 1000-1500.. himadri_sm Hardware Q&A 4 18-05-2010 06:57 AM
Please help in building a new rig: Urgent falling Hardware Q&A 36 07-02-2010 02:25 PM
Suggest Me a Multimedia + Gaming Rig krishnandu.sarkar Hardware Q&A 11 26-10-2009 04:03 PM
