Old 26-05-2010, 01:36 PM   #1 (permalink)
Question help: assembling a new machine
Hello everyone,
I am configuring a new machine.. which I would be buying sometime around second week of june from Nehru Place…
I would be using this for occasional gaming, development and graphics realated applications…..
Here is the list.. which I have prepared with the help of already available discussions on this forum… so here is the list…
AMD Athlon II X4 Quad X4 - 630 --------4647
Asus M4A78STD-V-EVO ---------------------6500
2 GB DDR3 ----------------------------------------2547
Samsung 23" P2350 LCD -----------------10800
WD 1 TB -------------------------------------------3542
Samsung DVD-Writer 22xD ---------------1023
Creative Inspire 2.1 T3130 ----------------1752
LOGITECH COMBO BCO KIT --------------619
Microtek 800VA ---------------------------------2333
HP Deskjet F4488 All-in-One Printer --3424
T.V TUNER (INTERNAL) ----------------------600
wireless router N150 ------------------------1895
Logitech Dual Action Gamepad -------1100
Cabinet - NZXT Gamma -------------------2000
PSU - FSP Saga II 400W ------------------2000
Total ----------------------------------------------44782
44782
Please have a look on the components and the prices (according to my knowledge)….
My budget was ~ Rs.40k.. which has already been crossed… that is the reason why I’m delaying an extra 2GB memory and graphics card…
Please give your comments on..
1) if I should consider some other component…
2) if prices are different..
3) or anything related…
that was about the hardware…
I also need some suggestion on the operating system…
Currently, I am using windows 7 (32 bit) on my dell 1420…
But with this new machine I’m planning to move ahead with win 7, 64 bit version…
I have already used vista 64 bit.. and didn’t find any problem…
That time I didn’t do any gaming on that machine… so my question is how good or bad 32 bit games run on 64 bit win 7….
Waiting for your comments….
Rajat.
rajputrajat is offline
Old 26-05-2010, 02:18 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: help: assembling a new machine
64BIT is fine.
---------- Post added at 02:18 PM ---------- Previous post was at 02:17 PM ----------
Also, get 4GB RAM.
asingh is online now
Old 26-05-2010, 02:33 PM   #3 (permalink)
Originally Posted by asigh View Post
64BIT is fine.
Also, get 4GB RAM.
i have heard that 32 bit games run with lower FPS on 64 bit OS...
if this is correct .... generally how much drop we see in %..?
and yes, i would definitely buy an extra 2GB...but after couple of months....
Old 27-05-2010, 12:56 AM   #4 (permalink)
as you mentioned gaming. let it be occasional or causal. try get a graphics card in. ok get these
ok. X4 is good.
get something like Biostar TA785G3 HD @ 4.1k
stick to 2Gb for now.
get 20" or 22" from Benq & save 3k min.
get 500Gb for now.
why not APC 550VA? 1.8k or so.
get this one later.
nice choice if u can find.
stick to this PSU. good one.
now with the saved money, get HD4670 or try get HD5670 512Mb. pc will be in balance & all your apps will be good to run.
Sam is online now
Old 27-05-2010, 03:17 AM   #5 (permalink)
CG Artist++
Hsakarp_kahtap's Avatar
NZXT GAMMA @2000-where u will find it@Rs.2000 in nehru palace?, yesterday i went to smc international they told it will be available in next week but will cost 2.6k.
AMD Phenom 1055T @3.5 GHz|| MSI 890 GXM- G65||12 G.B G-Skill Ripjaws 1600 MHz || Segate 500 GB*2 + 1T.B|| CM 690 II Advance|| Cosair VX 550|| MSI NGTX 460 || APC 650 || WD MY Passport 500 G.B USB 3.0 ||
Hsakarp_kahtap is offline
Old 27-05-2010, 10:09 AM   #6 (permalink)
i have not searched the market as such...
but have seen this price somewhere on the internet itself...
2.6k is definitely high... doesn't SMC quote higher than other shops???
---------- Post added at 09:50 AM ---------- Previous post was at 09:40 AM ----------
right..!
ok. X4 is good.
it does not have 128MB GDDR3 sideport memory as the ASUS one...
don't u think this would matter performance wise...?
what about MSI 785GM-E65?
i think this is also a good choice... and i saw it somewhere priced at ~4k....
i will be using this for HD movies watching, so this I prefer not to touch...
get 500Gb for now.
man.. i already got more than 500gb of stuff (movies, HD videos)...
better no to do anything here...
with that suffice for my machine?
in that case i would chose APC...
get this one later.
can do that....
thanks to you guyz...
i'm planning to spend ~10k on the graphics... so it's better to wait some more time...
---------- Post added at 10:09 AM ---------- Previous post was at 09:50 AM ----------
just now i was looking at the HD HD5670 card.... sweet...
how much does it cost (and which manufacturer)....?
thanks,
rajat.
Old 27-05-2010, 10:38 AM   #7 (permalink)
15.0 GHz
VarDOS's Avatar
whats the real use of the machine, as you have selected AIO printer?
VarDOS is offline
Old 27-05-2010, 10:50 AM   #8 (permalink)
this machine will be for watching movies, development, some gaming, browsing...
all purpose...
since i do not have any printer and scanner... that's why i am taking an all in one printer too with it....
Old 27-05-2010, 10:52 AM   #9 (permalink)
Alive Again...
satyamy's Avatar
nice rig found no problem
1) but for tv tuner get a good branded one like Pinnacle
2) 2GB RAM Ok...... but get 4GB RAM (either now or in future no problem)
3) for budget issue u can purchase later extra components likes gamepad, printer
4) if i was purchasing new system i will go for wireless keyboard mouse(any Microsoft, Logitech or Iball) @ Rs. 1400/-
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 27-05-2010, 11:02 AM   #10 (permalink)
if u not know, Asus quality in the budget motherboard section coming down. so better stay away from Asus when they look good at first sight.
Biostar TA785G3 HD got 128Mb DDR3 Samsung memory onboard. so no problem on that side. moreover the sideport memory does help. it boost performance by 5-8%, provided you OC the IGP. but if you planning game on 22-23" with IGP, sideport or no-sideport. game will SUCK.
MSI 785GM E65 is another good & solid board. both support processor upto 140W. so go for whichever you like. MSI will usually cost 1.5k more.
than forget gaming for now. IGP & 23" won't run same time. if you try gaming. it'll spoil your day.
than settle for 1Tb Green from Western Digital.
you mentioned about some 10k card. so get a UPS accordingly if you got something like HD5770 in your upgrade roadmap.
if able get Sapphire or PowerColor or MSI. these manufacturers give out 512Mb version of HD5670 & with custom cooler (2 slot occupying) & so the GPU runs really cool. also got OC potential. get 512Mb version. 1Gb version a waste. too much memory, too less muscle to use.
now decide, whether you want get the card now or wait. waiting will bring the price of card to 8k or so. for HD5770.
Sam is online now
Old 27-05-2010, 11:35 AM   #11 (permalink)
Thumbs up Re: help: assembling a new machine
thanks satyamy....
1) you are right.. for TV tuner card, i should go for better options...
here is one question.... does anybody know any TV tuner card (available in local market) which works on Linux too...
because i use kubuntu as my default OS....
3) i can delay printer purchase...
4) wireless peripherals would not be as much of the use, in my case...and also the changing batteries....no..
---------- Post added at 11:35 AM ---------- Previous post was at 11:07 AM ----------
alright then, i better chose MSI or Biostar
i was searching, why Biostar is so cheaper than MSI.. and found that it doesn't have solid capacitor....
what could be the cost of it?
anyways, i think Biostar has got everything i need.. so this would be my first choice now...
even if i play the games on low resolution? (please excuse my naiveness)
how much should i go for?
1k?
i was looking at some of the options.. and i like 5750, 1Gb...seems VFM and sufficient to my needs...
thanks for suggesions,
rajat.
Old 27-05-2010, 01:43 PM   #12 (permalink)
solid caps limited to processor area only. cost 4-4.2k
at low or mid resolution, games will run. but just it'll look ugly.
1k?
APC 650VA is best, provided you don't try Crossfire or end up getting a HD5870
try get the cheapest HD5770. cause HD6760 price still same but HD5770 price coming down.
Sam is online now
Old 28-05-2010, 02:59 AM   #13 (permalink)
CG Artist++
[QUOTE=rajputrajat;1241493]i have not searched the market as such...
Yep,as compared to Computer empire ther pice is 100-Rs.200 high in many product, ie msi 5670
Computer empire price - 6250
SMC-6400
Cosair VX 450
Smc -3900
Computer Empire-3750.
wht do with an old p3 machine? raja2281 Hardware Q&A 6 22-05-2010 11:58 AM
Mind Power Machine rhasta Random News 1 11-02-2010 08:44 PM
Setting Up a Virtual Machine using MS VPC iMav Tutorials 7 24-06-2009 12:55 PM
Backup, recover your *nix systems: Apple's time machine ripped apart! infra_red_dude Open Source 1 07-02-2008 03:07 AM
help me - machine hanging like hell - vendor help less amit_arya QnA (read only) 8 01-06-2005 11:14 AM
