Old 26-05-2010, 12:33 PM   #1 (permalink)
mac555's Avatar
Default building pc for gaming....thought required
i am buying the following parts....so guidance required
budget->48,000(excluding monitor and graphics card)
proc- amd x6 1055t
mobo- gigabyte 890gpa ud3h
ram- gkill 4gb
hdd- seagate 1tb
cabby- cm690
psu- corsair 650
mouse and keyboard- ?
ups- ?
dvd drive- ?
pc will be used for gaming....will purchase stuff from delhi(nehru place)...
In the end he will suffer,in the end we will triumph,in the end "there will be only CHAOS"...
mac555 is offline   Reply With Quote
Old 26-05-2010, 01:24 PM   #2 (permalink)
teh tech saviour!
saurabh_1e's Avatar
Default Re: building pc for gaming....thought required
Amd Phenom x6 1055t------->10.5k
Mobo Msi 890fx 11k
ram g skill 2x2 gb 1333mhz 6.3k
seagate 1 tb 4.5k
cabby cm690 4.5k
corsair 650tx 6.4k
mouse and keyboard logitech wireless 1.4k
ups 50va apc 2.3k
dvd drive sony dl dvd rw 1.2k
AMD Phenom x6 1055T @3.50ghz || MSI R6850 @925Mhz OC/PE || 2X2 GB RIPJAWS 1333CL8 || CM 460W REAL POWER ||Asus M5A97 EVO || Lancool PC-K62 || Sennheiser HD201+Fiio E5 || Logitech G400+Razer Golathius || Epson TX121 with CISS || Arch Linux ||
saurabh_1e is offline   Reply With Quote
Old 26-05-2010, 01:24 PM   #3 (permalink)
Jaskanwar Singh's Avatar
i suggest the following-
but make sure you buy or have a graphic card.
Core i7 930 2.8GHz @ 13.9k
MSI X58 Pro @ 10.8k
Transcend 2*2GB DDR3 1333MHz C9 @ 5.8k
Seagate Barracuda 7200.12 1TB @ 4.2k
LG 22x DVD @ 1.1k
Corsair VX550W @ 4.7k
NZXT M59 @ 3.8k
Logitech Multimedia Keyboard/Mouse Combo @ 0.8k
total = 45.1k
Old 26-05-2010, 01:28 PM   #4 (permalink)
teh tech saviour!
saurabh_1e's Avatar
gigabyte board will be too costly leave it
msi is more vfm
biostar 890fx will come for 7.5k but i am not sure of it quality
Old 26-05-2010, 02:00 PM   #5 (permalink)
Techie By Heart
mavihs's Avatar
Can you fill the below questionnaire so i can suggest you a good config!
1. What is your MAX budget?
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
3. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
4. Planning to overclock?
7. What resolution will the screen run at?
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 26-05-2010, 02:03 PM   #6 (permalink)
msi is more vfm
i think i7 is better for gaming
Old 26-05-2010, 02:04 PM   #7 (permalink)
Techie By Heart
mavihs's Avatar
NZXT M59 @ 3.8k
NZXT isn't available in Delhi!
@OP
which GPU will you be adding, as the SMPS will depend on that!
Old 26-05-2010, 02:08 PM   #8 (permalink)
MSI X58 Pro @ 10.8k
LG 22x DVD @ 1.1k
NZXT M59 @ 3.8k
total = 45.1k
really great config. just change ram to a better one & the HDD to WD Black. done.
Old 26-05-2010, 02:22 PM   #9 (permalink)
Techie By Heart
mavihs's Avatar
MSI X58 Pro @ 10.8k
i7 has tri-channel not dual channel!
Old 26-05-2010, 03:25 PM   #10 (permalink)
changing ram and hdd -
MSI X58 Pro @ 10.8k
Corsair TW3X4G-1600C9DHX 4GB Kit @ 6.6k
Western Digital Caviar Black 1TB @ 5.3k
LG 22x DVD @ 1.1k
NZXT M59 @ 3.8k
total = 47k
Old 26-05-2010, 03:37 PM   #11 (permalink)
teh tech saviour!
saurabh_1e's Avatar
for ram get gskill 3x 2gb tri channel kit 1333mhz or
3 x 1gb tri channel kit 1333mhz
tri channel is supported by core i 7 9xx and it will be faster than dual channel
---------- Post added at 03:34 PM ---------- Previous post was at 03:32 PM ----------
and get 2 x 500gb hdd
I always prefer 2 x 500gb hdd because even if one fails you are left with your imp data saved and your rig working
---------- Post added at 03:37 PM ---------- Previous post was at 03:34 PM ----------
nzxt may be available with smc international
when i bought my rig from him on 18 may he told me that he is getting few nzxt cabby within two weeks
Old 26-05-2010, 03:43 PM   #12 (permalink)
3x2 gb tri channel is costly
i found this on itwares -
G.SKILL 3GB (3 x 1GB) DDR3 1333 Triple Channel Kit Model F3-10666CL9T-3GBNQ @ 4.7k
Old 26-05-2010, 03:43 PM   #13 (permalink)
mac555's Avatar
i would be getting ati 5770 or ati 5850(if funds available).....and isnt i7 way at dead end as sandy bridge coming in 2011...and am3 way more future proof...And i will overclock too as i have sunbeamtech core contact freezer 120....
Old 26-05-2010, 03:47 PM   #14 (permalink)
teh tech saviour!
saurabh_1e's Avatar
if overclocking and want to be future proof then go with amd blindly.
these were only the reason i got an amd phenom x6 1055t .
Old 26-05-2010, 03:49 PM   #15 (permalink)
Sandy Bridges will only revolutionize i3 & i5. it'll bring graphics turbo. not much for i7 or say nothing for i7 to be precise.
Old 26-05-2010, 03:51 PM   #16 (permalink)
intel will not wipe out core i7 when sandy bridge comes.
i7 will overclock beyond 4ghz mark easily
Old 26-05-2010, 03:53 PM   #17 (permalink)
mac555's Avatar
1. What is your MAX budget? ->48000
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? ->yes
3. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that) ->gaming,coding and some video editing and stuff
4. Planning to overclock? ->yes
5. Which OS are you planning to use? ->windows and ubuntu
6. How much hard drive space is needed? ->500gb-1tb
7. What resolution will the screen run at? ->1920*1080
8. How would you rate your hardware knowledge from the count of 1-10? (1 being the lowest, 5 being you are somewhat in sync with the current performers and 10 being the highest) ->5
9. Have you ever built a desktop before or will this be done by an assembler? ->by me
10. When are you planning to buy the system?->in a week or so
11. Are you one of the types looking out for "future proof" configurations? ->yes
12. Are there going to be any components that you don't want to include in this new rig? ->monitor and graphics
13. Which city do you live in and are you open to buying from shops from other city/states? ->delhi,will purchase from delhi only...
Old 26-05-2010, 04:46 PM   #18 (permalink)
Techie By Heart
mavihs's Avatar
thats going to go way out of his budget with good RAM!
i7 9xx doesn't support dual channel!
nope! they only deal in CM!
& who was this person? i've personally talked to the head of SMC & they will never get NZXT cabbies!
MSI X58 Pro @ 10.8k
total = 47k
don't you get it, dual channel doesn't work in i7 9xx!
the socket change for i7 is going to take place in end 2011 or starting 2012
Old 26-05-2010, 05:13 PM   #19 (permalink)
WHAT? who told so? it do support Dual Channel. Single Channel. Triple Channel. just the performance will be different. if you don't believe me, look out here:will dual channel ram work triple
Dual-stick DDR3 kits work just fine. 1366 motherboards can handle single, dual and triple channel memory configurations.
You will have to check your manual to see which specific slots it requires, but it'll work.
most probably will be based on Intel X68 chipset.
Old 26-05-2010, 05:18 PM   #20 (permalink)
Super Moderator
asingh's Avatar
@Mavihs:
i7 architecture does support dual channel. If multiple of 2x DIMMs are loaded it moves to dual channel, and if 3x DIMMs aer loaded it adjusts to tri-channel. Its is how the memory controller sees the whole chunk on memory modules docked. Here is a review with analysis of dual vs tri channel.
asingh is online now   Reply With Quote
Old 26-05-2010, 05:21 PM   #21 (permalink)
by 2012, i3 & i5 will have a shift to 22nm & Ivy Bridge & i7 from Nahalem to haswell.
Old 26-05-2010, 07:49 PM   #22 (permalink)
Techie By Heart
mavihs's Avatar
WHAT? who told so?
Originally Posted by asigh View Post
@Mavihs:
thanx for the info guys!
---------- Post added at 07:48 PM ---------- Previous post was at 06:07 PM ----------
Amd P2 x6 1055T - 10.5k
Asus M4A87TD/USB3 - 6.2K
RAM GSkill 2GB x2 DDR3 1600MHz Ripjaws - 7.5K
WD 1TB Black - 5.2K
CM 690 - 4.3K
CM GX 650W - 5.7K
Mouse: Logitech MX518 - 1.4K
Keyboard: Microsoft Comfort Curve - 1K
UPS: APC 600VA (should be around 2.8K but not sure)
HP 24x DVD WR - 1.5K
Old 26-05-2010, 08:19 PM   #23 (permalink)
teh tech saviour!
saurabh_1e's Avatar
the person there was Mr. Gurmeet (think so)
He told me he is getting around 12-15 nzxt cabby model he doesn't know and cost was around 2.4k so i thought they must be overpriced gamma only.
Old 26-05-2010, 09:40 PM   #24 (permalink)
bORn To RIse....
rahul.007's Avatar
but he doesn't stock nzxt(anything except coolermaster)....
i called him yesterday to inquire about the price of kingston 2 gb ddr3 1333mhz(2.7k), cm hyper 212 (2.1k) and asked for some other stuff 2 as usual(nzxt m59, hd 5670, phenom II*6 1055t)....
he said he doesnt keep any cabby's except cooler master but if someone wanted nzxt m59 badly, he could try an arrange one for around 4k....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline   Reply With Quote
Old 26-05-2010, 10:12 PM   #25 (permalink)
Super Moderator
asingh's Avatar
WHY..the heck are you guys paying premium for products available online..? Yes, SMC does not host anything else but CM cabinets.
Old 26-05-2010, 11:35 PM   #26 (permalink)
rkneo11's Avatar
go for a core i7 or atleast a corei5 over AMD...
A day without laughter is a day wasted.-Charlie Chaplin.
rkneo11 is offline   Reply With Quote
Old 27-05-2010, 12:43 AM   #27 (permalink)
Techie By Heart
mavihs's Avatar
when did he tell you this?
it'll cost the same, even if you order online as the shipping costs a lot!
Old 27-05-2010, 03:39 AM   #28 (permalink)
CG Artist++
Hsakarp_kahtap's Avatar
Yesterday i went to smc and enquired for the AMD rig+ NZXT GAMMA cabby , they told me, they ordered 50 NZXT cabby and it will cost around 2.6k and will be come in 1-3rd of june .
AMD Phenom 1055T @3.5 GHz|| MSI 890 GXM- G65||12 G.B G-Skill Ripjaws 1600 MHz || Segate 500 GB*2 + 1T.B|| CM 690 II Advance|| Cosair VX 550|| MSI NGTX 460 || APC 650 || WD MY Passport 500 G.B USB 3.0 ||
Hsakarp_kahtap is offline   Reply With Quote
Old 27-05-2010, 09:15 AM   #29 (permalink)
bORn To RIse....
rahul.007's Avatar
2.6k for gamma!!!! never man.... ye to mujhe batae hue price se bhee jyada hai....
Old 27-05-2010, 09:48 AM   #30 (permalink)
Super Moderator
asingh's Avatar
No it does not. You need to ask the online shop, at times they offer good shipping methods at cheaper prices (which are not on their portal). Last year I ordered a CPU,2 GPUS, RAM, PSU, CM690, Motherboard, CM 120mm FANS all from Lynx. There were two large boxes. One for the components and one was the original CM690 box. Guess how much I paid for freight/courier till my doorstep. Rs. 450.
Heck even so suppose you pay a bit extra for the shipping, since cabinets are heavy. See the positive side -- do not need to go to the vendors shop, you get what you want sitting at your home in a cool a/c room. People may argue that they want to see the tangible product, but if one has researched enough online, it is easy to make out the product. Seeing the product physically will hardly tell you features.
how to integrate .net framework required by a software application on to itself? chandra_S Software Q&A 10 27-05-2010 01:40 PM
need help in building a rig blacrobous Hardware Q&A 13 26-05-2010 01:29 PM
is gfx card required 4 photoshop?? The Day Walker! Graphic cards 3 19-03-2010 07:23 PM
Please help in building a new rig: Urgent falling Hardware Q&A 36 07-02-2010 02:25 PM
Looking to buy a Mobile, your help is required friends! Thor Hardware Q&A 3 22-01-2010 01:51 AM
