Old 25-05-2010, 09:41 PM   #1 (permalink)
Jaskanwar Singh's Avatar
Default suggestions needed
hi guys,
my father is buying 2 new pcs for his office.
use - microsoft office and some other basic programmes
budget - 10k for each (proccy, mobo, ram, hard disk, cabinet+psu)
i thought about this -
Athlon II X2 250 3GHz @ 3K
Biostar A780G M2+SE @ 2.7k
Kingston Value RAM 1GB DDR2 @ 1.3k
WD 160GB @ 1.6k
cabinet + psu 300W @ 1k
total=9.6k
what do you think?
Jaskanwar Singh is online now
Old 25-05-2010, 10:00 PM   #2 (permalink)
Cool Buddy's Avatar
Default Re: suggestions needed
This is a good config, however it would be better to go for DDR3 RAM. And go for a 400W PSU, they don't consume more power but are safer.
Cool Buddy is offline
Old 25-05-2010, 11:40 PM   #3 (permalink)
Originally Posted by Jaskanwar Singh View Post
hi guys,
WD 160GB @ 1.6k
total=9.6k
what do you think?
Athlon II X2 250 3GHz @ 3K ---> should get cheap/ say 2.8k or so.
Biostar A780G M2+SE @ 2.7k ---> can go. or check if other manufacturers giving 740G or 760G based mobo for same pricing.
Kingston Value RAM 1GB DDR2 @ 1.3k ---> 2Gb DD2. A-Data will cost 1.9k or 2k.
WD 160GB @ 1.6k ---> 160Gb only? get 320Gb @ 1.7k
cabinet + psu 300W @ 1k ---> get slightly better 1. will cost 1.2k or so.
Sam is online now
Old 26-05-2010, 03:37 PM   #4 (permalink)
@ sam
which mobo you recommend in 2.5k range
Old 26-05-2010, 03:54 PM   #5 (permalink)
@ sam
here.. however its DDR3 based.
Sam is online now
Old 26-05-2010, 04:03 PM   #6 (permalink)
ddr3 would then raise the cost
Old 26-05-2010, 05:06 PM   #7 (permalink)
yes, but mobo cost will come down. well, difference between DDR2 & DDR3 around 400-500 bucks only. not too bad i'll say.
Sam is online now
Old 26-05-2010, 08:58 PM   #8 (permalink)
now which one of these-
Athlon II X2 250 @ 3K
Gigabyte GA-MA74GMT-S2 @ 2.7k
Transcend 1GB 1333MHz DDR3 @ 1.6k
WD 160GB @ 1.6k
cabinet + psu 300W @ 1.2k
total-10.1k
Transcend 2GB DDR2 @ 1.9k
WD 160GB @ 1.6k
total-10.4k
Old 26-05-2010, 10:08 PM   #9 (permalink)
X2 250 price ok. the board should cost less. say 2.5k. 1Gb DDR3 will cost close to 1.9k maybe. also i feel 320Gb best choice now. it'll cost almost same as 160Gb.
Sam is online now
Old 26-05-2010, 11:42 PM   #10 (permalink)
rkneo11's Avatar
if you are not going to be using tally may i suggest you to use Ubuntu 10.04 with Firefox for browsing and OpenOffice.org instead of Office... It will run smother than windows on the above mentioned specs and will save you loads of cash too...
A day without laughter is a day wasted.-Charlie Chaplin.
rkneo11 is offline
Old 27-05-2010, 01:14 PM   #11 (permalink)
so the first one is the better option???
Old 27-05-2010, 01:28 PM   #12 (permalink)
yes. go with first option.
Sam is online now
Old 27-05-2010, 08:49 PM   #13 (permalink)
ok thanks
Suggestions needed for power supply & cooling solution lubu Hardware Q&A 1 02-05-2010 06:39 PM
Need suggestions on buying a good cellphone.. Sid_gamer Buying Advice 34 15-04-2010 02:04 PM
Suggestions needed to buy a new DVD-Writer Yoda Hardware Q&A 10 18-03-2010 06:08 AM
Suggestions needed for purchase ajai5777 Hardware Q&A 11 12-02-2010 06:30 PM
Installing VLC in FC-6??? The Unknown Open Source 14 20-08-2007 06:39 PM
