Old 25-05-2010, 03:09 PM   #1 (permalink)
Default Laptop keys
some keys of my dell latitude laptop keys are not working..
plz suggest me what to do..
is it possible to repair..? or i have to get it replaced? if replaced how much it will cost..
also plz tell me how much laptop batteries will cost
starzlove is offline   Reply With Quote
Old 20-06-2010, 01:59 AM   #2 (permalink)
Default Re: Laptop keys
most probably this might be a keyboard problem. regarding the prices and the exact cause of the problem its best if you contact dell customer support. [i had the same issue and got it resolved pretty quickly]
burnout.paradise is offline   Reply With Quote
Old 20-06-2010, 06:17 AM   #3 (permalink)
Cool Buddy's Avatar
it is possible to get it repaired, but will depend on the exact problem. Get it checked from dell customer support
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 30-06-2010, 10:40 PM   #4 (permalink)
Well it really depends on the problem, if the key is broken or missing you should be able to just replace either the retainer clip or replace the entire dell laptop key, if its liquid damage, then you need to get a new keyboard. For best answer, we need more details.
appleboyz is offline   Reply With Quote
acer laptop and big trouble , urgent help needed fun2sh Laptops and Netbooks 6 19-04-2010 08:10 PM
F* keys need holding Fn key on Compaq CQ62 chandru.in Hardware Q&A 0 07-04-2010 02:14 PM
3.5" SATA HDD powerd by Laptop k_mridul Hardware Q&A 0 28-02-2010 04:21 PM
Acer Aspire 4720 Z Laptop Review FilledVoid Reviews 8 11-01-2008 05:06 PM
