Old 25-05-2010, 02:26 PM   #1 (permalink)
geek........
Gauravs90's Avatar
Default CPU overheating
Hi guys
I have Pentium 4 2.8 GHz Northwood processor
My problem is that proccy is overheating, on idle it's 50 C and on load it goes over 80 C & I recently changed mobo
I think it's because voltage of core is always between 1.6 to 1.7 Is it normal?
Pls help
Gauravs90 is offline
Old 25-05-2010, 02:50 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: CPU overheating
No ways can the vCore be that high. Could you tell your full system specification, and post the first and mainboard tab of CPU-Z.
asingh is online now
Old 25-05-2010, 03:14 PM   #3 (permalink)
geek........
Gauravs90's Avatar
Take a look
Old 25-05-2010, 03:45 PM   #4 (permalink)
core voltage normal. maybe bit high. its 130nm based P4. check the heatsink. it maybe faulty or fan not running at full speed or dust clogged its fins.
Sam is online now
Old 25-05-2010, 04:55 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Which board you have..?
Old 25-05-2010, 05:24 PM   #6 (permalink)
geek........
Gauravs90's Avatar
It's a local one of LOZU company
It has I915 series chipset
Old 25-05-2010, 06:19 PM   #7 (permalink)
Super Moderator
asingh's Avatar
Well I guess you will not be able to lower vCore. Most you can do is to clean out the system. Remove the HSF, clean the surfaces (CPU/HSF) with Isopropyl Alcohol, apply good TIM, reseat the HSF.
Old 25-05-2010, 10:05 PM   #8 (permalink)
Cool Buddy's Avatar
Did you change the mobo yourself?
Cool Buddy is offline
Old 25-05-2010, 11:07 PM   #9 (permalink)
geek........
Gauravs90's Avatar
^^^ Nope my vendor done that
I'm going to keep this ancient computer for only next three months afterthat i will buy laptop when i take admission in college.
IIT result coming tomorow!!!!!!!!!!!!!!!!!!!!!!!!! wish me luck guys.
Wish me luck for AIEEE also as i'm hoping better result in AIEEE.
Thanks asigh & sam.shab for helping.
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
Please List Basic C2D / Dual Core Overclocking Tips Choto Cheeta Overclocking 101 18-12-2007 09:31 PM
Nokia Processors - Hope its useful! solomon_paulraj Mobiles and Tablets 4 31-10-2007 02:57 PM
