Hi, I have a Gigabyte GA G31M S2L motherboard, fitted with a 2gb RAM....I plan to add another 1 GB RAM in it to play Split/Second in Windows 7(It's a game)
Will it be safe to combine a 2GB RAM and a 1GB RAM????
And what would be the price of a 1gb Transcend 800 Mhz RAM??
Game Developement Student by Profession.....Gamer by Hobby
Yes.But the frequency of both should be same.
1GB ddr2 would be 1.3k and 2gb @2.5k
Its better to go for 2gb as you wont waste a slot putting 1gb.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
Check the existing RAM frequency with speccy. If it is more than a year old, chances are, it would be 667Mhz in which case your computer won't be stable if you add 800Mhz RAM.
Just one question, doesn't split/second run with 2GB RAM?
@Cool Buddy.....It's a 800 Mhz RAM.....sure bout that
@everyone else....Am going for a 1 GB RAM Not due to OS Constraints but due to Budget Constraints(Which is the worst sort of constraint to have these days, i hear!!!)
Oh and Thnx for the prices!!
Could you show me any link which says that a Microsoft Windows 32BIT OS can realize/see full 4GB of ram..?
I have read somewhere that 32bit can be made to realize more RAM
for example servers running on 32bit operating system can recognise more than 4 GB of RAM
