Old 24-05-2010, 02:37 PM   #1 (permalink)
Default need help in building a rig
Hello friends,
I need some help in building a rig.
Budget is 35k with no monitor.
I already own a Pc with this config
Intel Core 2 Duo E7200
Intel DG35EC mobo
4Gb DDR2 Transcend ram
Palit ATI Hd4850 512mb gfx card
500W smps
500gb Hdd
I just thought of upgrading processor and stuff at first but seems like these new processors require new mobos and DDR3 ram so i need to go for a full upgrade. Havent thought of any preliminary config yet help would be appreciated.
blacrobous is offline
Old 24-05-2010, 03:23 PM   #2 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Default Re: need help in building a rig
Originally Posted by blacrobous View Post
Hello friends,
Intel DG35EC mobo
500W smps
500gb Hdd
Your rig isnt at all obsolete.Just upgrade your proccy only to a core2quad Q9400 and save some k's.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline
Old 24-05-2010, 03:36 PM   #3 (permalink)
Techie By Heart
mavihs's Avatar
Can you fill the below questionnaire so i can suggest you a good config!
1. What is your MAX budget?
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
3. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
4. Planning to overclock?
7. What resolution will the screen run at?
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline
Old 24-05-2010, 03:37 PM   #4 (permalink)
laborare est orare
Cilus's Avatar
Your current configuration is very good and no need to upgrade right now. The best way of upgrading is to go for new 6 core processors from AMD. in the end of this year a lot of new processors are coming out. So wait till now.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now
Old 24-05-2010, 04:06 PM   #5 (permalink)
i agree with ajai. change proccy to C2Q 94**. change card to HD5870 or GTX470 (custom cooled). & your PSU, if it is from Cooler Master extreme series or a cheap one. done. enjoy.
no need change motherboard. ram. etc.
Sam is online now
Old 24-05-2010, 04:12 PM   #6 (permalink)
bORn To RIse....
rahul.007's Avatar
yup.... no need to spend extra vitamin m on getting a whole new rig.... your rig is good for very much everything.... just upgrade the proccy, gpu and psu(if from cm extreme power series like sam said)....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline
Old 25-05-2010, 03:30 AM   #7 (permalink)
The point why i want to upgrade is that iam facing a lot of problems with this SMPS from Zebronics 500W and computer becomes laggy with this proccy when i compile code and stuff. I need this rig for Programming , and of course gaming . And moreover i heard it isnt that safe to OC this mobo. If it isnt worth it to upgrade right now and if i should wait a bit i can. Please Suggest.
Old 25-05-2010, 06:24 AM   #8 (permalink)
Cool Buddy's Avatar
By a Corsair VX 450W or 500W for around 2.5-3k and wait for 6 core processors from AMD to become more mainstream and cheaper, then upgrade. As they are already in the market, you won't have to wait very long either. Plus, after 6-8 months you'll also get DDR3 RAMs cheaper as well as USB 3.0 & maybe even SATA3 Motherboards at lower prices. This Isn't a very a good time for an upgrade considering your existing configuration.
As far as overclocking is concerned, Don't even try it if you are already having problems with your PSU unless you change it. As for the lag, make sure there are no problems in windows (PC becomes slow if windows installation is more than a year old & not well maintained).
Cool Buddy is offline
Old 25-05-2010, 07:07 AM   #9 (permalink)
cheap psu + good graphics card don't mix well. upgrade PSU is must. now decide, whether you want upgrade or almost fully new one. if simple upgrade, i already suggested. if a new cpu, better wait (& its worth too).
Sam is online now
Old 25-05-2010, 08:27 AM   #10 (permalink)
Super Moderator
asingh's Avatar
Your RIG is fine, and will still hold up. By the way, at what resolution you play games at. First things first, change your PSU, even the HD4850 is a risk on that PSU. You gaming resolution is important.
Next:
If you really want to save money, sell that motherboard, get an OC'able LGA775 package board, and see performance go up by 20-25%. It has a decent Mx of 9.5. Also get a good OEM HSF and you should be done with a nice upgrage..say in 15-18K which would include the HSF,better PSU, OC board.
Also I doubt you will find a Q9xxx for cheap anymore. They are kind of close to gold now. Hard to find, unless you can bump upon a resale deal.
asingh is online now
Old 26-05-2010, 04:55 AM   #11 (permalink)
yah ill upgrade the PSU at any cost and ill wait for that full upgrade. Suggest a nice PSU so that i dont have to sell it off again during the next upgrade. Normally i play games at 1280x1024 , sometimes on 1600x1200 depends actually on the game that i play on. As every one is saying to wait for that AMD 6 cores proccy ill wait and yah this Q9400 is running scarce in market i enquired the rate my dealer told me was 17k lol.
Thank You for the help guys
Old 26-05-2010, 09:17 AM   #12 (permalink)
I am the night! I am....
vickybat's Avatar
Go for Corsair psu's as they are excellent.You can try out the Vx 450 @ 3.8k or the vx 550 @ 4.7k. The latter is beefier and can support the 5850 or 5870 with ease.If you want sli or crossfire then look at corsair tx 650,750 or 850 according to your use.Refer latest prices thread of this forum or visit lynx india for prices.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is online now
Old 26-05-2010, 10:36 AM   #13 (permalink)
Can you even suggest a nice desktop case i got bored with this case iam having right now need something which is under 5k and even a nice motherboard which can be OC'able and which can give nice performance with this present processor and gfx card i have
Old 26-05-2010, 01:29 PM   #14 (permalink)
bORn To RIse....
rahul.007's Avatar
if under 5k, then get cm 690II.... nice cabby.... or you may even get nzxt m59.... great cabby at that price(3.8k)
http://www.lynx-india.com/index.php?productID=10972
Help building a gaming rig vicky2008 Hardware Q&A 10 15-04-2010 12:23 AM
Need Help in building my new Gaming Rig Sid_gamer Hardware Q&A 84 18-03-2010 05:08 PM
Need a gaming RIG in 55k cool.vicky Hardware Q&A 5 12-02-2010 02:00 PM
Please help in building a new rig: Urgent falling Hardware Q&A 36 07-02-2010 02:25 PM
