Old 23-05-2010, 11:02 PM   #1 (permalink)
Default Please suggest PSU, HDD & DVD writer
Hi Friends,
Please give suggestion regarding following -
1) A suitable PSU for my system,
2) A good DVD writer (please specify model number) &
3) 1 TB HDD.
MY System - Phenom II 550BE, Biostar Ta790GXB, 20 in LCD & 15 in CRT, 4GB DDR2 etc. I use it for 15-16 hrs daily, sometimes heavy downloading & sometime office work (MS Office, photoshop, acrobat, pagemaker etc.).
Budget - 8k, can be increased if required.
Thanks.
delhiuser is offline
Old 23-05-2010, 11:08 PM   #2 (permalink)
Cool G5's Avatar
Default Re: Please suggest PSU, HDD & DVD writer
PSU - Corsair CX 400W = Rs.2,900
DVD Writer - HP DVD1260 = Rs.1,300
HDD - WD 1 TB = Rs.5~6K(Don't know exact price, plz check)
Cool G5 is offline
Old 23-05-2010, 11:42 PM   #3 (permalink)
Hi,
Thanks for swift reply & suggestion.
Few friends suggested Corsair VX450, if graphic cards added to the system. Secondly, What is your thought regarding online purchase (delta, lynx etc).
Thanks again.
Old 24-05-2010, 12:29 AM   #4 (permalink)
sriharsha_madineni's Avatar
Originally Posted by delhiuser View Post
Hi,
Thanks again.
If you want some room for upgrade then VX450 is the way to go. A Solid PSU from Corsair and 80+ certified.
You can go ahead with online purchase, infact I bought my vx450 online
---------- Post added at 12:29 AM ---------- Previous post was at 12:25 AM ----------
Good PSU for his current config. But don't you think the new Optiarc Writers from Sony are better.
For that price you can get a 2TB now Price of HDD have fallen.
1TB should be around 3.5K now
[Intel E8400]+[Intel DP35DP]+[4GB DDR2]+[GTX 560Ti]+[Corsair VX450]+[Altec Lansing VS3251R 5.1]+[DELL S2409W]+[Logitech MX-518] [iPod Touch 32GB] [iPhone 4 16GB] [Galaxy S II] [Sony Vaio EB26]
sriharsha_madineni is online now
Old 24-05-2010, 08:12 AM   #5 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Hi Friends,
3) 1 TB HDD.
Thanks.
FSP Saga II 500 @ 2.6k A good PSU and cheaper than corsair vx 450W
Sony DVD RW 22x @1.1k
WD Caviar Green 1TB is available @3.5k but for 15-16hrs computing blue or black suggested @4.4k
or Seagate 1TB @ 4.2k
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline
Old 24-05-2010, 10:31 AM   #6 (permalink)
15.0 GHz
VarDOS's Avatar
Stick to Corsair VX450, avoid Sony Optical Drive better go for SAMSUNG. WD Blue will be good enough.
VarDOS is offline
Old 24-05-2010, 12:33 PM   #7 (permalink)
Cool Buddy's Avatar
1TB Seagate is available in Kolkata for 3.1k, seeme prices are higher in other regions.
There's nothing much to differentiate between optical drives, various people have good & bad experiences with various companies. I've had a good experience with my LG writer & a very bad one with lite-on.
Cool Buddy is offline
Old 24-05-2010, 12:51 PM   #8 (permalink)
15.0 GHz
VarDOS's Avatar
^ 4 - 5 people here had bad experience with sony including ME!, so I'll always suggest SAMSUNG Drive.
VarDOS is offline
Old 24-05-2010, 02:40 PM   #9 (permalink)
Cool G5's Avatar
Actually the optical drives made these days are not robust. You have to be lucky to get a drive which doesn't develop tray problems or other like not able to write to DVD(inspite of being a DVD Writer).
Cool G5 is offline
Old 24-05-2010, 03:11 PM   #10 (permalink)
Tech.Masti's Avatar
What about Gigabyte 460w psu? Is this good enough?
I have one noobish question... Please dont laugh... Can we add those good psu in basic cabinets from iball and zebronics., ....
Tech.Masti is offline
Old 24-05-2010, 03:14 PM   #11 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
My 5 year old Sony DVD RW is still working fine in my old config.Also I have assembled many PC's for my friends and all of them having Sony DVD RW.All are working fine.
---------- Post added at 03:14 PM ---------- Previous post was at 03:11 PM ----------
Gigabyte APFC 460W is good for your current config.It can be fit in most iball and zebby cabbys.
ajai5777 is offline
Old 24-05-2010, 04:28 PM   #12 (permalink)
Ofcourse you can My VX450 fits perfectly in iBall Workhorse cabinet.
Old 24-05-2010, 04:38 PM   #13 (permalink)
for the one who started this rig:
get FSP Saga 2 400W or Gigabyte 460W. both same unit. choose whichever is cheaper. or go Corsair way (CX400) if u prefer 5yrs warranty.
for HDD, get WD Green 32Mb cache version.
LG or Samsung 22X DVD writer. getting Sony or Asus no bad decision. but if something goes wrong, remember Rashi Peripherals will show u exit door.
Sam is online now
DVD Writer not detected raviramgopal Hardware Q&A 3 17-05-2010 02:17 PM
Lg dvd writer Hitarth Hardware Q&A 0 17-05-2010 01:04 PM
DVD Writer Help sumangh01 Hardware Q&A 6 26-04-2010 01:48 PM
Battle of DVD Rippers: Easy VS Fast bigit Open Source 1 28-01-2010 12:09 PM
DVD writer queries h_kunte Hardware Q&A 10 26-11-2006 01:40 PM
