@mahvis
1. What is your MAX budget?-- 35-36k
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why? plz tell me if there is smthng like that
3. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that) Internet, C#, gaming and Java in the near future
4. Planning to overclock? No
5. Which OS are you planning to use? Windows 7 and Ubuntu 10.04
6. How much hard drive space is needed?- 250 or 320
7. What resolution will the screen run at? thats not a problem to me. it shuld just be good
8. How would you rate your hardware knowledge from the count of 1-10? (1 being the lowest, 5 being you are somewhat in sync with the current performers and 10 being the highest) 7.5
9. Have you ever built a desktop before or will this be done by an assembler? no ( leave an assembler let me decide first of all!!!)
10. When are you planning to buy the system? 27th May
11. Are you one of the types looking out for "future proof" configurations? future proof for next 4 years
12. Are there going to be any components that you don't want to include in this new rig? If yes, do mention. no
13. Which city do you live in and are you open to buying from shops from other city/states? Lucknow; NO
14. Mention any other points if deemed necessary.- I wanted to know that will a laptop be able to endure i mean keep working till 4 years??; i want performance+ portability(not important)+ endurance
http://www.facebook.com/home.php?#!/...17620324930523
