Old 22-05-2010, 10:13 AM   #1 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Talking Buying some "small stuff"
I'm going to SP Road and National Market (bangalore) today and/or tomorrow and am on the hunt for some small purchases all totaling to under 1K.
Things include:
  1. Bluetooth USB Adapter
  2. USB Hub to split 1 USB port into many
  3. Many-in-one card reader (better if its integrated with USB hub)
  4. Blank DVD's
  5. A pendrive for testing (will take the cheapest stuff from national market)
  6. Data Cable for Nokia 5130 XpressMusic
  7. Data Cable for Nokia 2323 Classic
  8. A cheap pair of 3.5mm jack earphones
  9. An earphone jack splitter for my laptop - to split one 3.5mm jack into two 3.5mm jacks
  10. 3.5mm jack to 2.5mm jack converter
  11. Nokia thin pin to phat pin adapter
  12. Nokia thin pin to samsung GT1410 type new pin adapter
Though I may not buy all the above stuff.....
Anyway, can you guys please suggest expected prices for these and how much I can bargain ??
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 22-05-2010, 10:18 AM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Default Re: Buying some "small stuff"
One thing I would like to aware you that, the USB hub u buy, check if its high speed.
I threw at least three such hubs 1-to-4 as they were not recognizing as high speed when plugged into PC, any USB drive I plug in, one message comes "This USB could perform better...."
Now bought one "Belkin" 1-to-4 hub @350/- or something I guess, and its working fine.
b/w, this is the product I'm talking about.
LINK
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 22-05-2010, 10:23 AM   #3 (permalink)
The Smaller Bang
Aah OK. But am still planning to go for something cheaper...
Old 22-05-2010, 11:10 AM   #4 (permalink)
himadri_sm's Avatar
i bought one such splitter for only Rs.10/-...i am using it with my PC along with a headphone extension cable(which i bought for Rs.30/-)
View my Portfolio here-
Pixels and Polygons | On Linkedin | On Facebook
Available for freelance. PM me for details.
MSI 890 GXM G65, Phenom X6 1055T, G.Skill 1600Mhz "Ripjaws" 2x2gb Kit, MSI GTX 470, WD Black 500Gb, NZXT Gamma, Corsair Vx550, Hp 22x DVD-Rw, Benq G2420HD, Logitech Mx-518, Xbox 360 Gamepad for PC
himadri_sm is offline
Old 22-05-2010, 04:46 PM   #5 (permalink)
Cool Buddy's Avatar
Blank DVDs:
Single layer:
Moser baer 12, sony 13
Good quality local 9.50
bad quality local 8
Dual Layer:
OK quality local 20
Moser baer 45
Single layer Rewritable:
Moser baer 45
Prices in Kolkata, Do tell your prices for the components you buy, I'd love to know as these small things are not discussed often
Cool Buddy is offline
Old 22-05-2010, 05:00 PM   #6 (permalink)
The Smaller Bang
Am nearing majestic... National Market a brief walk away. I am carrying my laptop with me to test the components incase they are duds. But mostly I won't buy much today. Just check prices...
Old 22-05-2010, 09:51 PM   #7 (permalink)
Cool Buddy's Avatar
Please give the prices, I want to compare it with Bangalore as it is possible for me to source components from there if it is cheaper.
Old 23-05-2010, 11:15 AM   #8 (permalink)
The Smaller Bang
Nokia 2323's data cable. That guy started at 150. I was like WTF. Went down to 80 but then didn't buy it since I felt the actual cost must be a lot lower.. What should I pay for a data cable ?
Old 23-05-2010, 03:15 PM   #9 (permalink)
Cool Buddy's Avatar
If you go to nokia priority, they will start at 300-400. I think 80 was OK
Old 24-05-2010, 05:26 AM   #10 (permalink)
The Smaller Bang
Hmmm.... Fine then. Maybe I'll buy it the coming saturday.
This time I ended up buying only electronic components (OP-AMP 741C, a handful of LED's, some diodes, four transistors and a breadboard to experiment on).
Old 25-05-2010, 09:58 AM   #11 (permalink)
static_x's Avatar
  1. Bluetooth USB Adapter - Rs. 100
  2. USB Hub to split 1 USB port into many - Buy branded ones as rhitwi ck said...LOGTECH 4 Port @ Rs.500
  3. Many-in-one card reader (better if its integrated with USB hub) - RS.100-150
  4. Blank DVD's - MOSER BAER PRO @Rs.11/each
  5. A pendrive for testing (will take the cheapest stuff from national market) - 2 GB @ Rs.250
  6. Data Cable for Nokia 5130 XpressMusic - CANT SAY
  7. Data Cable for Nokia 2323 Classic - CANT SAY
  8. A cheap pair of 3.5mm jack earphones - anything between 75-150 but poor ones
  9. An earphone jack splitter for my laptop - to split one 3.5mm jack into two 3.5mm jacks - Rs. 25-125
  10. 3.5mm jack to 2.5mm jack converter - Rs.25
  11. Nokia thin pin to phat pin adapter - CANT SAY
  12. Nokia thin pin to samsung GT1410 type new pin adapter- CANT SAY
Phenom II X4 940, Gigabyte MA790GP-UD4H, Corsair 6GB DDRII, AOC Fovi F22, Creative Gigaworks T3 Speakers, NZXT Phantom, Corsair GS600, 15 TB HDDs, Shure SRH440, Klipsch S4i, Ipod Touch 64gb
static_x is offline
Worth buying Dell Inspiron 15R Laptop (T540506IN8) bajaj151 Hardware Q&A 13 26-05-2010 07:19 PM
Buying a Digital Camera jackal_79 Cameras and camcorders 14 22-04-2010 05:47 PM
Is Nokia N900 worth Buying ? augustya Buying Advice 4 06-04-2010 12:23 PM
Help in buying Wireless router !!!!!! 047 Hardware Q&A 2 30-03-2010 05:51 PM
Buying a new PC... need suggestions! rahul941400 Hardware Q&A 24 18-02-2010 04:21 PM
