Old 21-05-2010, 07:44 PM   #1 (permalink)
Default I want to buy Handy cam
HI,
i am planning to buy a handy cam. i must be able to record videos, snap photos, use memory cards and the like features.
The Mega pixel and zoom length should be quite good.
my budget is 10k.
could you please suggest me good product in my budget..
thanks
Ravindar
ravindarjobs is offline   Reply With Quote
Old 22-05-2010, 10:36 PM   #2 (permalink)
The Researcher
Default Re: i want to buy Handy cam
you won't get a good handycam for 10k. extend your budget a further say 5k and you can get models with flash memory plus card. Have a look at thhe link of Sony india.
http://www.sony.co.in/productcategory/cam-camcorder
Ramakrishnan is offline   Reply With Quote
Old 29-05-2010, 05:53 PM   #3 (permalink)
Default Re: I want to buy Handy cam
ok,
i have a basic question?
can we record videos with digital cam?
because i see that digital cams are available in my budget. so if we can record videos with it, then for me i think it would be better to go for digital cams.
Old 29-05-2010, 06:40 PM   #4 (permalink)
Cool G5's Avatar
You can record videos with your digicam but in your budget you won't get anything over 640*480 with mono sound. Can you stay with it?
Also a handycam will record much better quality videos than a digicam. Digicam is primarily designed to take photographs.
Cool G5 is offline   Reply With Quote
Old 02-06-2010, 05:21 PM   #5 (permalink)
alright, i decided to go for Digital Cam. could you please suggest best ditigat cam in my budget.
Old 02-06-2010, 10:22 PM   #6 (permalink)
Cool G5's Avatar
Hunt for Canon A1100IS under Rs.10K.
Need to buy a laptop in about 40K - 50K aneek Hardware Q&A 1 07-05-2010 04:43 PM
Want to Buy Arcticlean !! karan_kewlz Hardware Q&A 3 06-05-2010 06:44 PM
Need to buy a capacitor please help Tech&ME Hardware Q&A 2 04-05-2010 08:07 AM
Looking to buy a Mobile, your help is required friends! Thor Hardware Q&A 3 22-01-2010 01:51 AM
planning to buy digi cam, HELP Needed?? abhineet Buying Advice 5 26-06-2008 02:49 AM
